N5k Jumbo Frames not correctly displayed
We have two 5548UP with 6.0.2-N2 with N2k in FEX, single homed, and FCoE, and we´ve been facing performance issues.
I´ve configured the network-qos policy to permit 2158 MTU for the FCoE, and 1500 MTU for default traffic. On the statistics of all interfaces (even the ones where only Ethernet is going) I can see a bunch of Jumbo Frames.
Here´s the Network QoS config:
policy-map type network-qos fcoe-default-nq-policy
    class type network-qos class-fcoe
      pause no-drop
      mtu 2158
    class type network-qos class-default
      mtu 1500
      multicast-optimize
 system qos
   service-policy type network-qos fcoe-default-nq-policy
All the "show interface" and "show queuing interface" commands display the MTU of 1500, while, for example, on the interface towards the CORE´s (6500) where there is no FCoE, only ethernet, there are bunch of Jumbo Frames.
Any idea where these Jumbos are coming from?!?
richbarb
Hi Mateja,
In the Nexus 5500 platform, any frame size higher than 1518 is considered jumbo frame.
It seems doesn't makes sense if you don't have configured jumbo frame in your network/devices and you see these counters incrementing.
But if you includes ethernet and the dot1q tag(if trunking) which is 18 plus 4 for a total of 22 bytes of header. So if the host is sending/receiving frames with more than 1496 bytes of data you would see the Nexus 5k count these frame as jumbo.
Richard
