N7K
mohAmed khAdr
Level 3
Level 3
Got 3 Qs:
1) how do you save the config on N7K, or on NX in general?
2) How to do image upgrade?
3) Do I need to congif STP? and if so, do I need to config a switch as root? & how I can do that?
Thx.
6 Replies 6
mohAmed khAdr
Level 3
Level 3
What am asking is: do you just:  wr mem like IOS to save the config,.... or it's like the CatOS..just enter2wice.
Thx.
Hey Mohamed,
If you want to use the shorthand for write mem aka wr you can use the following command in configuration mode:
cli alias name wr copy run start
This will allow you to copy the running config to the startup config with the familiar wr syntax.
Jerry Ye
wri mem is not a valid CLI in the NXOS, you have to use copy run start.
For software upgrade procedure, please check out the upgrade guide.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_2/nx-os/upgrade/guide/Cisco_Nexus_7000_Series_NX-OS_Software_Upgrade_and_Downgrade_Guide__Release_4.2_chapter1.html
By default, STP is disabled in NXOS. If you have the proper license, you can enable STP, and configure it to fit your environment.
jerry
Thx. jerry,
Jerry,
Can you pls. avise on config redundancy for sup 1 on n7k?
Thx.
Can you post the output of the following commands after inserting the module standby SUP
show system redundancy status
show module
show boot auto-copy
jerry
