01-08-2021 01:42 PM
i have a question, can we replace Nexus 5548 which acts as NPIV SAN switch, with another switch Nexus 93180YC-Fx with NX-OS version 9.3(5) and ACI-STRG license, I want to know if the nexus 9k can provide the same functionality (NPIV, foce ) that offered by the nexus 5548.
thanks
01-08-2021 03:56 PM
as per the datasheet, it supports FCoE and NPV
01-08-2021 04:16 PM
01-08-2021 05:55 PM
But when activating FCoE feature and binding Vfc to physical interfaces toward an initiator (UCS) according to this reference, it works:
NX9K-B-SW1# show flogi database
INTERFACE VSAN FCID PORT NAME NODE NAME
fc1/1 1011 0x710020 20:08:00:0e:11:12:12:f2 20:07:00:0e:11:12:
12:f2
fc1/3 1011 0x710040 20:02:00:0e:11:12:12:f2 20:01:00:0e:11:12:
12:f2
vfc1/24 1011 0x710000 22:b8:00:3a:9c:a0:11:ff 23:f3:00:3a:9c:a0:
11:c1
vfc1/24 1011 0x710001 20:00:00:25:b5:27:1a:01 20:00:00:25:b5:27:
10:08
vfc1/24 1011 0x710002 20:00:00:25:b5:27:1a:02 20:00:00:25:b5:27:
10:07
Total number of flogi = 5.
NX9K-B-SW1# show interface vf
vfc vfc-port-channel
NX9K-B-SW1# show interface vfc1/24
vfc1/24 is trunking (Not all VSANs UP on the trunk)
Bound interface is Ethernet1/24
Hardware is Ethernet
Port WWN is 20:18:b0:c5:3c:05:d5:00
Admin port mode is F, trunk mode is on
snmp link state traps are enabled
Port mode is TF
Port vsan is 1011
Operating Speed is 10 Gbps
Admin Speed is auto
Trunk vsans (admin allowed and active) (1,1011)
Trunk vsans (up) (1011)
Trunk vsans (isolated) ()
Trunk vsans (initializing) (1)
41 fcoe in packets
4576 fcoe in octets
0 fcoe out packets
0 fcoe out octets
Interface last changed at Fri Jan 8 23:53:02 2021
However, it's not working with netapp FAS2620:
(we noticed that Po212 is sending traffic out to NetApp but no 'in traffic')
Any solutions plz.
01-24-2023 04:18 AM
Hi Bhavin,
so you were able to do zoning, FCoE and everyting as on 5Ks?
Did it work on the end?
