01-25-2021 07:12 AM
Hello everyone
I am configuring the replacement of a Nexus 5672UP, connected by 10GB Eth to a Storage NetApp AFF C190. It works NFS or iscsi.
as I understand the replacement would be the N9K-C93180YC-FX, but I'm not sure if I need the ACI-STRG license to be able to fulfill the requirement.
Can you help me?
Solved! Go to Solution.
01-25-2021 07:57 AM
Both NFS and iSCSI work over IP, so from perspective of N9K, both are just IP traffic. So no need for ACI STRG license.
The ACI-STRG license is required if you want to enable FC NPV, FCoE NPV or SAN switching.
Stay safe,
Sergiu
01-25-2021 07:57 AM
Stay safe,
Sergiu
09-29-2021 06:38 AM
I wanted to ask a followup question: how do you activate the ACI-STRG license ? Does it come via smartnet or via PAK codes ?
We ordered it with a switch but it is not installed on it from factory (the advanced license is, but the ACI-STRG not)
