NAS200 drive failure
Thomas Grassi
My NAS200 will not allow me to add a second drive to the unit.
I had two drives in the NAS200 then we had a power outage. Then NAS000 is on a ups but the power was out for 24 hours
After the power came back on the drive in bay one failed put drive two was ok
I was able to recover the data because I had Raid  setup on the drives.
But I got a replacement drive and it never comes active
I took the good drive in bay two and placed it in bay 1 and it works
I put it in Bay 2 and it still works
I just can not get another drive to work in this unit
Any ideas or suggestions
Tom
Thomas R Grassi Jr
Nisar Sayed
is the second (replaced) drive from the same vendor (make, model and speed-rpm)? if yes, then it could be the conflicting firmware version, either it is older or newer. I have experience the similar issue, I end up upgrading everything to same version, including the BIOS. OR the new drive is bad already.
Nisar
Nisar Sayed
Nisar
bom dia perdi o cd de intalaçao agora nao consigo abaixar algeum poderia me ajudar
