Need Help configuring UCS connect to secondary storage
andreas.perdana
Dear  All ,
Need guide step by step configuring UCS ,connect to secondary direct attach storage. Using FI 6324.  Little bit confused , if I need to create new policies or use existing policies. As far as I know , I had to create new vsan , CMIIW. Need clear advice about step by step to connect to  secondary direct attach storage.
Best Regards.
Walter Dey
Hi Andreas
To connect the storage, you indeed a separate VSAN (resp. a new pair for fabric A and B); but in addition, you also have to create additional vfc interfaces for your service profiles; why ? a vfc can only be member of one VSAN.
