Hello, at work they recently connected an Isilon server to a Nexus 3172. I am connected with a QSFP broken into 3 interfaces to 3 nodes on the Isilon. I can log into the Isilon and see all interfaces are up with an MTU configured of 9000 but I can not ping above 1472. My config below has 9216 but I had it set at 9000 and it did not work. Am I missing anything in my configuration or is there not enough output shown below?
policy-map type network-qos jumbo
class type network-qos class-default
mtu 9216
system qos
service-policy type network-qos jumbo
interface Ethernet1/50/1
switchport access vlan 131
speed 10000
interface Ethernet1/50/2
interface Ethernet1/50/3
HOSTNAME# show int eth 1/50/1 | grep MTU
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
HOSTNAME# show queuing interface ether 1/50/1 | grep MTU
HW MTU: 9216 (9216 configured)
--- 192.168.131.19 ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 1.135/1.233/1.362 ms
HOSTNAME# ping 192.168.131.19 packet-size 1472
PING 192.168.131.19 (192.168.131.19): 1472 data bytes
1480 bytes from 192.168.131.19: icmp_seq=0 ttl=62 time=1.359 ms
1480 bytes from 192.168.131.19: icmp_seq=1 ttl=62 time=1.098 ms
1480 bytes from 192.168.131.19: icmp_seq=2 ttl=62 time=1.242 ms
1480 bytes from 192.168.131.19: icmp_seq=3 ttl=62 time=1.424 ms
1480 bytes from 192.168.131.19: icmp_seq=4 ttl=62 time=1.589 ms
round-trip min/avg/max = 1.098/1.342/1.589 ms
HOSTNAME# ping 192.168.131.19 packet-size 1473
PING 192.168.131.19 (192.168.131.19): 1473 data bytes
Request 0 timed out
Request 1 timed out
Request 2 timed out
^C
4 packets transmitted, 0 packets received, 100.00% packet loss
