Nexus 5000 n55-m16up SFP not present
lwilfredoflor
Hi Cisco Community,
Currently Im working on a case in witch I have the following:
actually two Nexus both with the following PDI and running 7.0(6)N1(1)
N5K-C5596UP-SUP
N55-M16UP
N55-M160L3-V2
for the N55-M16UP we have 50% eth and the other 50% FC
1-8 eth
9-16 fc
only one of the Nexus its recognizing the SFP for ETH and FC (im going to call it Nexus2), the other one its only recognizing the SFP for ETH (im going to name it Nexus1). on Nexus1 when we put the ports 1-8 on eth and 9-16 on FC the sfp its good just on eth port but not on FC port, If I change the FC to ETH then the SFP its present on the whole module.
I already changed the N55-M16UP, ensure the sfp compatibility and check the licence, the config its the same in both Nexus, same features were enable, so Would like to know if you guys could give any advice.
Thanks in advance
23 Replies 23
Walter Dey
check
https://supportforums.cisco.com/t5/storage-networking/configuring-fc-ports-on-cisco5548up/td-p/2379955
I think it is still true that:
If you're configuring a unified port as Fibre Channel or FCoE, confirm that  you have enabled  the feature fcoe command.
Hi Walter, thanks for the reply, currently FCOE feature its enable, here is the list of feature we have enable
feature fcoe
feature npiv
feature fport-channel-trunk
feature telnet
feature tacacs+
cfs eth distribute
feature ospf
feature interface-vlan
feature hsrp
feature lacp
feature dhcp
feature vpc
logging level vpc 4
feature lldp
feature vtp
feature fex
can you please post output of "show interface brief" for both switches.
You know, that the SFP's for ETH resp. FC are different ?
Hi Walter,
for both we are ussing the same PID  SFBR-5780AMZ-CS2 for SFP, according to the comp matrix, its compatible
Nexus with issues
MXZITN5K01# show interface brief
Interface Vsan Admin Admin Status SFP Oper Oper Port
Mode Trunk Mode Speed Channel
Mode (Gbps)
fc2/9 10 auto on sfpAbsent -- -- --
fc2/10 10 auto on sfpAbsent -- -- --
fc2/11 10 auto on sfpAbsent -- -- --
fc2/12 10 auto on sfpAbsent -- -- --
fc2/13 10 auto on sfpAbsent -- -- --
fc2/14 10 auto on sfpAbsent -- -- --
fc2/15 10 auto on sfpAbsent -- -- --
fc2/16 10 auto on sfpAbsent -- -- --
Ethernet VLAN Type Mode Status Reason Speed Por
t
Interface Ch
Eth1/1 1 eth trunk up none 10G(D) 1
Eth1/2 1 eth trunk up none 10G(D) 1
Eth1/3 3 eth access up none 1000(D) 3
Eth1/4 1 eth trunk down SFP not inserted 1000(D) 6
Eth1/5 1 eth fabric down SFP not inserted 1000(D) --
Eth1/6 1 eth fabric down SFP not inserted 10G(D) 101
Eth1/7 1 eth trunk up none 10G(D) 10
Eth1/8 1 eth trunk up none 10G(D) 20
Eth1/9 1 eth trunk down SFP not inserted 1000(D) --
Eth1/10 1 eth trunk down SFP not inserted 1000(D) --
Eth1/11 1 eth access down SFP not inserted 10G(D) --
Eth1/12 1 eth access down SFP not inserted 10G(D) --
Eth1/13 1 eth access down SFP not inserted 10G(D) --
Eth1/14 1 eth access down SFP not inserted 10G(D) --
Eth1/15 1 eth trunk up none 1000(D) --
Eth1/16 1001 eth access up none 1000(D) --
Eth1/17 1 eth trunk up none 1000(D) 3111
Eth1/18 1 eth trunk up none 1000(D) 3112
Eth1/19 1 eth trunk up none 1000(D) 3113
Eth1/20 1 eth trunk up none 1000(D) 3114
Eth1/21 1 eth trunk up none 1000(D) 3115
Eth1/22 1 eth trunk up none 1000(D) 3116
Eth1/23 1 eth trunk up none 1000(D) 3117
Eth1/24 1 eth trunk up none 1000(D) 3118
Eth1/25 1 eth trunk up none 1000(D) 3119
Eth1/26 1 eth trunk up none 1000(D) 3120
Eth1/27 1 eth trunk up none 1000(D) 3121
Eth1/28 1 eth trunk up none 1000(D) 3122
Eth1/29 1 eth trunk up none 1000(D) 3123
Eth1/30 1 eth trunk up none 1000(D) 3124
Eth1/31 1 eth trunk up none 1000(D) 3125
Eth1/32 1 eth trunk up none 1000(D) 3126
Eth1/33 1 eth trunk up none 1000(D) 3127
Eth1/34 1 eth trunk up none 1000(D) 3122
Eth1/35 1 eth trunk down Link not connected 1000(D) 3129
Eth1/36 1 eth trunk up none 1000(D) --
Eth1/37 1 eth trunk up none 1000(D) 3130
Eth1/38 1 eth trunk up none 1000(D) 3131
Eth1/39 1 eth access down SFP not inserted 10G(D) --
Eth1/40 1 eth access down SFP validation failed 10G(D) --
Eth1/41 1 eth access down SFP not inserted 10G(D) --
Eth1/42 1 eth access down SFP not inserted 10G(D) --
Eth1/43 1 eth access down SFP not inserted 10G(D) --
Eth1/44 1 eth access down SFP not inserted 10G(D) --
Eth1/45 1 eth access down SFP not inserted 10G(D) --
Eth1/46 1 eth access down SFP not inserted 10G(D) --
Eth1/47 1 eth trunk up none 1000(D) --
Eth1/48 1000 eth access down SFP not inserted 10G(D) --
Eth2/1 1 eth trunk up none 1000(D) --
Eth2/2 1 eth trunk up none 1000(D) --
Eth2/3 800 eth access up none 1000(D) --
Eth2/4 1 eth access down SFP not inserted 10G(D) --
Eth2/5 10 eth access up none 10G(D) --
Eth2/6 10 eth access up none 10G(D) --
Eth2/7 1 eth trunk up none 10G(D) --
Eth2/8 1 eth trunk up none 10G(D) --
Port-channel VLAN Type Mode Status Reason Speed Proto
col
Interface
Po1 1 eth trunk up none a-10G(D) la
cp
Po3 3 eth access up none a-1000(D) la
cp
Po6 1 eth trunk down No operational members 1000(D) no
ne
Po10 1 eth trunk up none a-10G(D) la
cp
Po20 1 eth trunk up none a-10G(D) la
cp
Po101 1 eth fabric down No operational members auto(D) no
ne
Po3111 1 eth trunk up none a-1000(D) la
cp
Po3112 1 eth trunk up none a-1000(D) la
cp
Po3113 1 eth trunk up none a-1000(D) la
cp
Po3114 1 eth trunk up none a-1000(D) la
cp
Po3115 1 eth trunk up none a-1000(D) la
cp
Po3116 1 eth trunk up none a-1000(D) la
cp
Po3117 1 eth trunk up none a-1000(D) la
cp
Po3118 1 eth trunk up none a-1000(D) la
cp
Po3119 1 eth trunk up none a-1000(D) la
cp
Po3120 1 eth trunk up none a-1000(D) la
cp
Po3121 1 eth trunk up none a-1000(D) la
cp
Po3122 1 eth trunk up none a-1000(D) la
cp
Po3123 1 eth trunk up none a-1000(D) la
cp
Po3124 1 eth trunk up none a-1000(D) la
cp
Po3125 1 eth trunk up none a-1000(D) la
cp
Po3126 1 eth trunk up none a-1000(D) la
cp
Po3127 1 eth trunk up none a-1000(D) la
cp
Po3128 1 eth trunk down No operational members 1000(I) la
cp
Po3129 1 eth trunk down No operational members auto(D) no
ne
Po3130 1 eth trunk up none a-1000(D) no
ne
Po3131 1 eth trunk up none a-1000(D) no
ne
Po3132 1 eth trunk down No operational members 1000(D) la
cp
Port VRF Status IP Address Speed MTU
mgmt0 -- down -- -- 1500
Interface Vsan Admin Admin Status Bind Oper Oper
Mode Trunk Info Mode Speed
Mode (Gbps)
vfc27 10 F on trunking Eth2/7 TF auto
vfc28 10 F on trunking Eth2/8 TF auto
Interface Secondary VLAN(Type) Status Reason
Vlan1 -- down Administratively down
Vlan3 -- up --
Vlan10 -- up --
Vlan12 -- up --
Vlan21 -- up --
Vlan54 -- up --
Vlan80 -- up --
Vlan81 -- up --
Vlan82 -- up --
Vlan83 -- up --
Vlan84 -- up --
Vlan100 -- up --
Vlan105 -- up --
Vlan109 -- up --
Vlan115 -- up --
Vlan117 -- up --
Vlan121 -- up --
Vlan140 -- up --
Vlan141 -- up --
Vlan186 -- up --
Vlan190 -- up --
Vlan201 -- up --
Vlan211 -- up --
Vlan221 -- up --
Vlan231 -- up --
Vlan241 -- up --
Vlan255 -- up --
Vlan1000 -- up --
Vlan1001 -- up --
Interface Status Description
Lo0 up --
Nexus without issues
MXZITN5K02# show int brief
Mode (Gbps)
fc2/9 20 auto on up swl F 8 --
fc2/10 20 auto on up swl F 8 --
fc2/11 20 auto on up swl F 8 --
fc2/12 20 auto on up swl F 8 --
fc2/13 20 auto on down lwcr -- --
fc2/14 20 auto on down lwcr -- --
fc2/15 20 auto on sfpAbsent -- -- --
fc2/16 20 auto on down lwcr -- --
Ethernet VLAN Type Mode Status Reason Speed Port
Interface Ch
Eth1/4 1 eth trunk down Link not connected 1000(D) 6
Eth1/5 1 eth access down SFP not inserted 10G(D) --
Eth1/6 1 eth access down SFP not inserted 10G(D) --
Eth1/9 800 eth access down SFP not inserted 1000(D) --
Eth1/10 1 eth access down SFP not inserted 1000(D) --
Eth1/11 1 eth trunk up none 1000(D) --
Eth1/12 1 eth access down Link not connected 1000(D) --
Eth1/13 1 eth access down Link not connected 1000(D) --
Eth1/14 1 eth access down Link not connected 1000(D) --
Eth1/15 1 eth trunk down Link not connected 1000(D) --
Eth1/17 1 eth trunk down Link not connected 1000(D) 3111
Eth1/18 1 eth trunk down Link not connected 1000(D) 3112
Eth1/19 1 eth trunk down Link not connected 1000(D) 3113
Eth1/20 1 eth trunk down Link not connected 1000(D) 3114
Eth1/21 1 eth trunk down Link not connected 1000(D) 311 5
Eth1/22 1 eth trunk down Link not connected 1000(D) 3116
Eth1/23 1 eth trunk down Link not connected 1000(D) 3117
Eth1/24 1 eth trunk down Link not connected 1000(D) 3118
Eth1/25 1 eth trunk down Link not connected 1000(D) 3119
Eth1/27 1 eth trunk down Link not connected 1000(D) 3121
Eth1/28 1 eth trunk down Link not connected 1000(D) 3122
Eth1/29 1 eth trunk down Link not connected 1000(D) 3123
Eth1/30 1 eth trunk down Link not connected 1000(D) 3124
Eth1/31 1 eth trunk down SFP not inserted 1000(D) 3125
Eth1/32 1 eth trunk down SFP not inserted 1000(D) 3126
Eth1/33 1 eth trunk down SFP not inserted 1000(D) 3127
Eth1/34 1 eth trunk down SFP not inserted 1000(D) 3128
Eth1/35 1 eth trunk down SFP not inserted 1000(D) 3129
Eth1/36 1 eth trunk down SFP not inserted 1000(D) 3130
Eth1/37 1 eth trunk down SFP not inserted 1000(D) 3130
Eth1/38 1 eth access down SFP not inserted 1000(D) --
Eth1/39 1 eth access down SFP not inserted 1000(D) --
Eth1/40 1 eth access down SFP not inserted 1000(D) --
Eth1/41 1 eth access down SFP not inserted 1000(D) --
Eth1/42 1 eth access down SFP not inserted 1000(D) --
Eth1/43 1 eth access down SFP not inserted 1000(D) --
Eth1/44 1 eth access down SFP not inserted 1000(D) --
Eth1/45 1 eth access down SFP not inserted 1000(D) --
Eth1/46 1 eth access down SFP not inserted 1000(D) --
Eth1/47 1 eth trunk down SFP not inserted 1000(D) --
Eth1/48 1 eth access down SFP not inserted 1000(D) --
Eth2/7 10 eth access down SFP validation failed 10G(D) --
Eth2/8 10 eth access down SFP validation failed 10G(D) --
col
Interface
cp
cp
ne
cp
cp
Po101 1 eth fabric down No operational members auto(I) no
ne
Po3111 1 eth trunk down No operational members 1000(D) no
ne
Po3112 1 eth trunk down No operational members 1000(D) no
ne
Po3113 1 eth trunk down No operational members 1000(D) no
ne
Po3114 1 eth trunk down No operational members 1000(D) no
ne
Po3115 1 eth trunk down No operational members 1000(D) no
ne
Po3116 1 eth trunk down No operational members 1000(D) no
ne
Po3117 1 eth trunk down No operational members 1000(D) no
ne
Po3118 1 eth trunk down No operational members 1000(D) no
ne
Po3119 1 eth trunk down No operational members 1000(D) no
ne
Po3120 1 eth trunk up none a-1000(D) no
ne
Po3121 1 eth trunk down No operational members 1000(D) no
ne
Po3122 1 eth trunk down No operational members 1000(D) no
ne
Po3123 1 eth trunk down No operational members 1000(D) no
ne
Po3124 1 eth trunk down No operational members 1000(D) no
ne
Po3125 1 eth trunk down No operational members 1000(D) no
ne
Po3126 1 eth trunk down No operational members 1000(D) no
ne
Po3127 1 eth trunk down No operational members 1000(D) no
ne
Po3128 1 eth trunk down No operational members 1000(D) no
ne
Po3129 1 eth trunk down No operational members 1000(D) no
ne
Po3130 1 eth trunk down No operational members 1000(D) no
ne
Po3131 1 eth trunk down No operational members auto(I) no
ne
Po3133 1 eth trunk down No operational members 1000(D) la
cp
Vlan3 -- up --
Vlan10 -- up --
Vlan12 -- up --
Vlan21 -- up --
Vlan54 -- up --
Vlan80 -- up --
Vlan81 -- up --
Vlan82 -- up --
Vlan83 -- up --
Vlan84 -- up --
Vlan100 -- up --
Vlan105 -- up --
Vlan109 -- up --
Vlan115 -- up --
Vlan117 -- up --
Vlan121 -- up --
Vlan140 -- up --
Vlan141 -- up --
Vlan186 -- up --
Vlan190 -- up --
Vlan201 -- up --
Vlan211 -- up --
Vlan221 -- up --
Vlan231 -- up --
Vlan241 -- up --
Vlan255 -- up --
Vlan1000 -- up --
Vlan1001 -- up --
Lo0 up --
calopez2
When you change the port type, are you reloading the Expansion module?
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/interfaces/7x/b_5500_Interfaces_Config_Guide_Release_7x/b_5500_Interfaces_Config_Guide_Release_7x_chapter_01.html#task_A6C551C739324293B020FD7C35F018D0
Show interface fc x/y capabilities
Show interface fc x/y transceiver details
You can compare output with working one.
If the transceiver is not recognized, you can also try the following to check status:
Interface fc x/y
service transceiver-unsupported
exit
Hi Calopez,
thanks for your response.
Yes we already reloaded the module when changing the Interface mode. I tryed the service transceiver-unsupported under interface level and global mode but nexus isnt accepting the command. Also I found this doc witch indicate that its necesary to reboot the whole switch https://www.cisco.com/c/m/en_us/techdoc/dc/reference/cli/nxos/commands/l2/port.html
This example shows how to configure a unified port on a Cisco N55-M16UP expansion module:
switch# configure terminal
switch(config)# slot 2
switch(config-slot)# port 32 type fc
switch(config-slot)# copy running-config startup-config
switch(config-slot)# reload
Nexus whith issues
MXZITN5K01# show int fc 2/16 transceiver details
fc2/16 sfp not present
MXZITN5K01# sho int fc 2/16 capabilities
fc2/16
fc2/16
Min Speed is 1 Gbps
Max Speed is 8 Gbps
FC-PH Version (high, low) (2,1)
Receive data field size (max/min) (2112/2112) bytes
Transmit data field size (max/min) (2112/256) bytes
Classes of Service supported are Class 3, Class F
Class 3 sequential delivery supported
Hold time (max/min) (10000/1) micro sec
BB state change notification not supported
Rate Mode change not supported
Rate Mode Capabilities Dedicated
Receive BB Credit modification supported yes
FX mode Receive BB Credit (min/max/default) (1/240/16)
ISL mode Receive BB Credit (min/max/default) (1/240/16)
Performance buffer modification supported no
FX mode Performance buffers (min/max/default) --
ISL mode Performance buffers (min/max/default) --
Out of Service capable yes
Beacon mode configurable no
MXZITN5K02# show int fc 2/9 transceiver details
fc2/9 sfp is present
Name is CISCO-AVAGO
Manufacturer's part number is SFBR-5780AMZ-CS2
Revision is G4.1
Serial number is AVD1905BE05
Cisco part number is
FC Transmitter type is short wave laser w/o OFC (SN)
FC Transmitter supports short distance link length
Transmission medium is multimode laser with 62.5 um aperture (M6)
Supported speeds are - Min speed: 2000 Mb/s, Max speed: 8000 Mb/s
Nominal bit rate is 8500 Mb/s
Link length supported for 50/125mm fiber is 50 m
Link length supported for 62.5/125mm fiber is 20 m
Cisco extended id is unknown (0x0)
No tx fault, no rx loss, in sync state, diagnostic monitoring type is 0x68
SFP Diagnostics Information:
Alarms Warnings
High Low High Low
Temperature 42.67 C + 75.00 C -5.00 C 70.00 C 0.00 C
Voltage 3.24 V 3.63 V 2.97 V 3.46 V 3.13 V
MXZITN5K02# show int fc 2/9 capabilities
fc2/9
fc2/9
Min Speed is 1 Gbps
Max Speed is 8 Gbps
According the datasheet https://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/data_sheet_c78-618603.html
Table 2 Cisco Nexus 5500 Platform Transceiver Support Matrix
this are the supported FC SFP's !
Cisco DS-SFP-FC4G-SW
4-Gbps Fibre Channel SW SFP, LC (for Fibre Channel expansion module ports)
Cisco DS-SFP-FC4G-LW
4-Gbps Fibre Channel LW SFP, LC (for Fibre Channel expansion module ports)
Cisco DS-SFP-FC8G-SW
8-Gbps Fibre Channel SW SFP+, LC (for Fibre Channel expansion module ports)
Cisco DS-SFP-FC8G-LW
8-Gbps Fibre Channel LW SFP+, LC (for Fibre Channel expansion module ports)
Hi Walter,
Actually on Nexus1 (failing one)
there are the following models
DS-SFP-FC8G-SW
DS-SFP-FC8G-LW
on Nexus2 (working one)
GLC-LH-SMD
Sorry, I am confused !
DS-SFP-FC8G-SW and DS-SFP-FC8G-LW are FC SFP's
GLC-LH-SMD is a 10G Ethernet SFP !
Are you really using FC SFP's in FC configured ports and Ethernet SFP's in Ethernet configured ports ?
for Nexus1
When interface is FC type
MXZITN5K01(config)# show int fc 2/9 transceiver
fc2/9 sfp not present
When we change to ETH it recognice the DS-SFP-FC8G-SW
Ethernet2/9
    transceiver is present
   type is 1Gbase-CISCO-AVAGO
    name is CISCO-AVAGO
    revision is G4.1
    serial number is AVD1905BE0V
    nominal bitrate is 8500 MBit/sec
    Link length supported for 50/125um OM2 fiber is 50 m
    Link length supported for 62.5/125um fiber is 21 m
    Link length supported for 50/125um OM3 fiber is 150 m
    cisco id is --
    cisco extended id number is 4
This is very odd !
1) have you tried to insert this sfp in any other FC configured slots ?
2) have to tried to swap a sfp from the working switch, and insert it here
3) try the opposite; insert this failing sfp on the working switch
4) the FC sfp in the Ethernet slot: can you do a "show interface fc1/48 transceiver Details"
5) inserting FC sfp's in Ethernet ports (and vice versa) doesn't make sense. It will never work.
 Hi Walter, Finally cu scheduled an MW to perform several task, all with the same result, the last we did was reload the device, after that N5K start recognized all SFP on FC interfaces
Rick1776
Level 5
Level 5
I’ve seen this is the past where you cannot mix modes you either need to have the slot run FC or just ETH but not both at the same time. This was awhile ago so I’m not sure if that has been fixed.
Also make sure the FC interfaces are from the last port moving inward.
Universal ports can be FC or classical Ethernet.
You need a contiguous block of only Ethernet (from left to right) and a contiguous block of FC from right to left.
see https://supportforums.cisco.com/t5/data-center-videos/how-to-configure-fc-and-ethernet-ports-on-nexus-5500-up-series/ba-p/3101916
