Nexus 5500 fc interface counters via SNMP
sokarlsson
I'm trying to pull fibre channel error statistic counters on a Nexus 5596 but it looks like the IF-MGMT mib is not implemented.
If there any OIDs accessbale via SNMP to get the following values (Examples from show output in the CLI) via snmp?
Input: discards, errors, CRC, unknown class, too long, too short, OLS, RR, NOS, loop inits, B2B credit remaining, B2B credit transitions from zero
Output: discards, errors, OLS, LRR, NOS, loop inits, B2B credit remaining, B2B credit transitions from zero
Steve Fuller
Level 9
Level 9
Have you looked at the CISCO-FC-FE-MIB (OID 1.3.6.1.4.1.9.9.289) ?
As per the Cisco Nexus 5000 Series MIB Support List there were a  significant number of OIDs added in the NX-OS 5.2(1)N1(1) release, and looking through the MIB I think a lot of what you're after is listed as supported.
