Nexus 5548UP - VFC error disabled
Robert Leers
We are building a Datacenter with UCS 6248U FIs and Nexus 5548UP Switches.
The problem ist the FCoE configuration on the Nexus. After creating the vfC-Interface it is member of the default-vsan1. When we try to assign it to an other vsan (here vsan 100), it goes down with "error disabled".
We have only the Interface e1/7 in port-channel 60 bound to vfc60, vsan 100 associated to vlan 710
I hope anybody has an idea what's the problem.
Here is an extract of our configuration:
RZ1NX001(config-if)# show run int e1/7
interface Ethernet1/7
  description FCoE Link to RZ2FI-A eth1/19
  switchport mode trunk
  switchport trunk allowed vlan 710
  channel-group 60 mode active
RZ1NX001(config-if)# show int e1/7
Ethernet1/7 is up
  Hardware: 1000/10000 Ethernet, address: 002a.6a53.5c2e (bia 002a.6a53.5c2e)
  Description: FCoE Link to RZ2FI-A eth1/19
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
RZ1NX001(config-if)# show run int po60
interface port-channel60
  spanning-tree port type edge trunk
  speed 10000
RZ1NX001(config-if)# show int po60
port-channel60 is up
  Hardware: Port-Channel, address: 002a.6a53.5c2e (bia 002a.6a53.5c2e)
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  Members in this channel: Eth1/7
RZ1NX001(config-if)# show run int vfc60
interface vfc60
  bind interface port-channel60
  switchport trunk allowed vsan 100
  no shutdown
RZ1NX001(config-if)# show int vfc60
vfc60 is down (Error disabled)
    Bound interface is port-channel60
    Hardware is Ethernet
    Port WWN is 20:3b:00:2a:6a:53:5c:7f
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
    Port vsan is 100
RZ1NX001(config-if)# show vlan fcoe
Original VLAN ID        Translated VSAN ID      Association State
      710                       100              Operational
Hello Robert,
The port-channel status is SD and member link is still I state. Have you tried flapping the port-channel interfaces ?
Also, NPV feature is enabled on N5K and I don't see NPIV  enabled on it.
Are you planning to run N5K in NPV mode ? If yes, I need to verify if FI can be connected to FC switch operating in NPV mode.
I guess FI is in FC End host mode ( NPV ) and it needs to be connected to FC switch with NPIV feature.
Padma
padramas
Hello Robert,
What is the UCSM and N5K version ?
From N5K
show feature | grep -i enabled
show fcoe
From UCS FI
connect nxos
show port-channel summary
--- same set of commands as you shared from N5K
Padma
Hello Padma,
N5K-Version is version 5.1(3)N2(1)
UCS-Manager is 2.1(2a)
We've configured the UCS with UCSM but the result looks similar to the N5K:
N5K:
RZ1NX001# show feature | grepp i enabled
% Invalid command at '^' marker.
RZ1NX001# show feature | grep -i enabled
fcoe                  1         enabled
fex                   1         enabled
interface-vlan        1         enabled
lacp                  1         enabled
lldp                  1         enabled
npv                   1         enabled
ospf                  1         enabled (not-running)
ospf                  2         enabled (not-running)
ospf                  3         enabled (not-running)
ospf                  4         enabled (not-running)
sshServer             1         enabled
vpc                   1         enabled
RZ1NX001# show fcoe
RZ1NX001#
(no output)
FI:
RZ1FI001-A(nxos)# show port-channel summary
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
Group Port-       Type     Protocol  Member Ports
      Channel
60    Po60(SD)    Eth      LACP      Eth1/19(I)
1026  Po1026(SU)  Eth      NONE      Eth1/1(P)    Eth1/2(P)    Eth1/3(P)
                                     Eth1/4(P)
1283  Po1283(SD)  Eth      NONE      Eth2/1/9(D)  Eth2/1/11(D)
1290  Po1290(SD)  Eth      NONE      Eth2/1/13(D)  Eth2/1/14(D)  Eth2/1/15(D)
                                     Eth2/1/16(D)
1292  Po1292(SD)  Eth      NONE      Eth2/1/17(D)  Eth2/1/18(D)  Eth2/1/19(D)
                                     Eth2/1/20(D)
1293  Po1293(SD)  Eth      NONE      Eth2/1/21(D)  Eth2/1/22(D)  Eth2/1/23(D)
                                     Eth2/1/24(D)
1295  Po1295(SD)  Eth      NONE      Eth2/1/29(D)  Eth2/1/30(D)  Eth2/1/31(D)
                                     Eth2/1/32(D)
1307  Po1307(SU)  Eth      NONE      Eth2/1/1(P)  Eth2/1/2(P)  Eth2/1/3(P)
                                     Eth2/1/4(P)
1309  Po1309(SU)  Eth      NONE      Eth2/1/5(P)  Eth2/1/6(P)  Eth2/1/7(P)
                                     Eth2/1/8(P)
RZ1FI001-A(nxos)# show run int e1/19
!Command: show running-config interface Ethernet1/19
!Time: Thu Oct 24 10:42:28 2013
version 5.0(3)N2(2.11.2a)
  description C: FcoeUplink
  pinning border
  switchport trunk allowed vlan 710,4048
  no shutdown
RZ1FI001-A(nxos)# show int e1/19
Ethernet1/19 is up
  Hardware: 1000/10000 Ethernet, address: 002a.6a3b.523a (bia 002a.6a3b.523a)
  Description: C: FcoeUplink
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
RZ1FI001-A(nxos)# show run int po60
!Command: show running-config interface port-channel60
!Time: Thu Oct 24 10:45:04 2013
  pinning border
  speed 10000
RZ1FI001-A(nxos)# show int po60
port-channel60 is down (No operational members)
  Hardware: Port-Channel, address: 002a.6a3b.523a (bia 002a.6a3b.523a)
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, 10 Gb/s
  EtherType is 0x8100
  Members in this channel: Eth1/19
RZ1FI001-A(nxos)# show vlan fcoe
      4048                      1                Operational
      710                       100              Operational
RZ1FI001-A(nxos)# show run int vfc 792
interface vfc792
  switchport mode NP
  no shutdown
RZ1FI001-A(nxos)# show int vfc792
vfc792 is down (Error disabled)
    Hardware is Virtual Fibre Channel
    Port WWN is 23:17:00:2a:6a:3b:52:7f
    Admin port mode is NP, trunk mode is on
    Port vsan is 100
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      0 frames input, 0 bytes
        0 discards, 0 errors
      0 frames output, 0 bytes
    last clearing of "show interface" counters never
RZ1FI001-A(nxos)# show vsan 100
vsan 100 information
         name:VSAN0100  state:active
         interoperability mode:default
         loadbalancing:src-id/dst-id/oxid
         operational state:down
Hello Robert,
Padma
Hello Padma,
this was the solution. After enabling npiv the vfc  shows "NPV upstream port not available". After disabling npv everthing  is fine. I confused npv and npiv.
Thank you for your help
Robert
