Nexus 5k Port channel issue - Physical port (Hot standby in bundle)
rawatsandeep
Hi guys,
I am having issues with a port channnel connected to the UCS server.Whenever I am putting physical port into portchannel it is going down, the physical port is going down with interface staus saying first - (Link not connected) and then finally (Hot standby in bundle). Portchannel remail down with status (No operational members)
What does this status message means :  Ethernet1/11 is down (Hot standby in bundle)
Below is the configuration:
interface Ethernet1/11
  no cdp enable
  switchport mode trunk
  switchport trunk allowed vlan 317,2511-2514
  spanning-tree port type edge trunk
  no snmp trap link-status
  logging event port link-status
  logging event port trunk-status
  channel-group 101 mode active
interface port-channel101
  vpc 101
ACC14# sh port-channel summ
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
Group Port-       Type     Protocol  Member Ports
      Channel
101   Po101(SD)   Eth      LACP      Eth1/11(H)
Below is what I have obeserved :
ACC14(config)# int eth1/11
ACC14(config-if)# no channel-group 101 mode active
ACC14(config-if)# sh int eth1/11
Ethernet1/11 is up
  Hardware: 1000/10000 Ethernet, address: 547f.ee24.4e92 (bia 547f.ee24.4e92)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 00:00:02
  30 seconds input rate 112 bits/sec, 14 bytes/sec, 0 packets/sec
  30 seconds output rate 232 bits/sec, 29 bytes/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 152 bps, 0 pps; output rate 248 bps, 0 pps
  RX
    0 unicast packets  1701 multicast packets  0 broadcast packets
    1701 input packets  368680 bytes
    0 jumbo packets  0 storm suppression bytes
    0 giants  0 input error  0 short frame  0 overrun   0 underrun
    0 watchdog  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 unicast packets  59044 multicast packets  5630 broadcast packets
    64674 output packets  5169139 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble
    0 Tx pause
  15 interface resets
ACC14(config-if)# sh int po101
port-channel101 is down (No operational members)
vPC Status: Down, vPC number: 101 [packets forwarded via vPC peer-link]
  Hardware: Port-Channel, address: 547f.ee24.4e92 (bia 547f.ee24.4e92)
  MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, 10 Gb/s
  EtherType is 0x8100
  No members
  0 seconds input rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  0 seconds output rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  Load-Interval #2: 0 seconds
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    0 unicast packets  0 multicast packets  0 broadcast packets
    0 input packets  0 bytes
    0 Rx pause
  TX
    0 output packets  0 bytes
    0 jumbo packets
    0 Tx pause
  0 interface resets
Ethernet1/11 is down (Link not connected)
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, 10 Gb/s, media type is 10G
  EtherType is 0x8100
  Last link flapped 00:00:10
  30 seconds input rate 48 bits/sec, 6 bytes/sec, 0 packets/sec
  30 seconds output rate 8056 bits/sec, 1007 bytes/sec, 8 packets/sec
    input rate 288 bps, 0 pps; output rate 2.30 Kbps, 2 pps
  RX
    0 unicast packets  1728 multicast packets  0 broadcast packets
    1728 input packets  374762 bytes
    0 Rx pause
  TX
    0 unicast packets  59637 multicast packets  5685 broadcast packets
    65322 output packets  5222148 bytes
    0 jumbo packets
    0 Tx pause
  15 interface resets
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  Members in this channel: Eth1/11
  30 seconds input rate 2192 bits/sec, 274 bytes/sec, 0 packets/sec
  30 seconds output rate 7296 bits/sec, 912 bytes/sec, 3 packets/sec
    input rate 216 bps, 0 pps; output rate 2.38 Kbps, 2 pps
  RX
    0 unicast packets  450 multicast packets  0 broadcast packets
    450 input packets  98735 bytes
    0 Rx pause
  TX
    0 unicast packets  980 multicast packets  12 broadcast packets
    992 output packets  143742 bytes
    0 jumbo packets
    0 Tx pause
  0 interface resets
ACC14(config-if)# sh lacp counters interface po101
ACC14(config-if)# int eth1/11
ACC14(config-if)# channel-group 101 mode active
                    LACPDUs         Marker      Marker Response    LACPDUs
Port              Sent   Recv     Sent   Recv     Sent   Recv      Pkts Err
port-channel101
Ethernet1/11       261    599      0      0        0      0        0
port-channel101
Ethernet1/11       261    600      0      0        0      0        0
port-channel101
Ethernet1/11       261    603      0      0        0      0        0
ACC14(config-if)#
ACC14(config-if)#
port-channel101
Ethernet1/11       261    605      0      0        0      0        0
ACC14(config-if)#
port-channel101
Ethernet1/11       262    610      0      0        0      0        0
ACC14(config-if)#
ACC14(config-if)#
Now no more LACP packets are sent or received
ACC14(config-if)#
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  30 seconds input rate 248 bits/sec, 31 bytes/sec, 0 packets/sec
  30 seconds output rate 128 bits/sec, 16 bytes/sec, 0 packets/sec
    input rate 96 bps, 0 pps; output rate 1.66 Kbps, 2 pps
  RX
    0 unicast packets  471 multicast packets  0 broadcast packets
    471 input packets  101618 bytes
    0 Rx pause
  TX
    0 unicast packets  988 multicast packets  12 broadcast packets
    1000 output packets  144925 bytes
    0 jumbo packets
    0 Tx pause
  0 interface resets
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  Last link flapped 00:01:03
  30 seconds input rate 160 bits/sec, 20 bytes/sec, 0 packets/sec
  30 seconds output rate 176 bits/sec, 22 bytes/sec, 0 packets/sec
    input rate 56 bps, 0 pps; output rate 1.58 Kbps, 2 pps
  RX
    0 unicast packets  1755 multicast packets  0 broadcast packets
    1755 input packets  378413 bytes
    0 Rx pause
  TX
    0 unicast packets  59651 multicast packets  5685 broadcast packets
    65336 output packets  5224084 bytes
    0 jumbo packets
    0 Tx pause
  15 interface resets
And just to let u know This po101 is a part of vPC, between 2 N5k. Other Switch's N5k port channel is up.
Thanks in advance...
Sandeep Rawat
Message was edited by: Sandeep Rawat
rawatsandeep
Hmmm.. Somebody pluged the cable going out of Eth1/11 to a wrong server, thus we were gettin status as Hot standby in bundle and not able to add the eth1/11 to port channel. Port-channel, port, and vpc came up after cable was placed correctly to right server.
