02-29-2012 10:01 AM
From what I have gathered from documentation the Nexus is able to mark any DSCP value between 0-63. I would assume it would be able to classify based on any DSCP value as well. The documentation however leads me to believe otherwise. The language for marking suggest valid values are from 0 to 63. For classification the language suggests classification can only match standard DSCP values. I would test but do not have a Nexus at my disposal. Can someone with experience please confirm?
Classification
Marking
regards,
ryan
Solved! Go to Solution.
03-02-2012 07:39 AM
Hi Ryan,
As you can see from my 5010 lab switch:
24.09.5010B.1(config)# policy-map type qos my_policy
24.09.5010B.1(config-pmap-qos)# class type qos my_class
24.09.5010B.1(config-pmap-c-qos)# set dscp ?
<0-63> DSCP value
af11 AF11 dscp (001010)
af12 AF12 dscp (001100)
af13 AF13 dscp (001110)
af21 AF21 dscp (010010)
af22 AF22 dscp (010100)
af23 AF23 dscp (010110)
af31 AF31 dscp (011010)
af32 AF32 dscp (011100)
af33 AF33 dscp (011110)
af41 AF41 dscp (100010)
af42 AF42 dscp (100100)
af43 AF43 dscp (100110)
cs1 CS1(precedence 1) dscp (001000)
cs2 CS2(precedence 2) dscp (010000)
cs3 CS3(precedence 3) dscp (011000)
cs4 CS4(precedence 4) dscp (100000)
cs5 CS5(precedence 5) dscp (101000)
cs6 CS6(precedence 6) dscp (110000)
cs7 CS7(precedence 7) dscp (111000)
default Default dscp (000000)
ef EF dscp (101110)
The only DSCP values you can set are 0-63, as you suspected.
However, these are the only DSCP values you are supposed to be able to match as well:
24.09.5010B.1(config-cmap-qos)# match dscp ?
<0-63> List of DSCP values
ef EF dscp (101110)
This output was taken on our latest version of code, and the 5500 series is the same.
- Amanda
03-02-2012 07:39 AM
Hi Ryan,
<0-63> DSCP value
ef EF dscp (101110)
ef EF dscp (101110)
- Amanda
03-02-2012 07:43 AM
Hello Amanda,
Thank you for the reponse! I spoke with an TME yesterday and he confirmed as well. Hopefully they will update the documentation.
regards,
ryan
03-02-2012 07:58 AM
Ryan,
I assume you're referring to this line:
Specified DSCP value or list of DSCP values. See
Table 1 for a list of valid DSCP values.
As far as I can tell the documentation does tell you you can add your own.
03-02-2012 08:18 AM
I started with the config guide which reads like this...
marking...
--you can set the DSCP value in the six most significant bits of the DiffServ field of the IP header to a specified value. You can enter numeric values from 0 to 63, in addition to the standard DSCP values shown in the table below:
classification...
--Configures the traffic class by matching packets based on the values in the dscp-list. The standard DSCP values are shown in the preceding table (only standard dscp values).
The marking section explicity states values 0 to 63. The classification does not.
When I read the command reference I wasn't sure if specified implied one from the table from table or if specified implied any DSCP 0-63.
regards,
ryan
