Nexus 7k - configuration of int tunnel failed
Holger Ray
I cannot configure a tunnel interface on a Nexus 7k
feature tunnel was enabled
config:
clu# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
clu(config)# feature tunnel
clu(config)# interface tunnel 0
clu(config-if)# tunnel source loopback1 clusaug(config-if)# tunnel destination 171.48.25.21 clusaug(config-if)# ip address 171.57.252.53/31 clusaug(config-if)# no shutdown
clu#
clu# sh interface tunnel 0 Tunnel0 is down (Hardware prog failed)
     Admin State: up
     Internet address is 171.57.252.53/31
     MTU 1476 bytes, BW 9 Kbit
     Tunnel protocol/transport GRE/IP
     Tunnel source 171.57.252.51 (loopback1), destination 171.48.25.21
     Transport protocol is in VRF "default"
     Rx
     0 packets input, 1 minute input rate 0 packets/sec
     Tx
     0 packets output, 1 minute output rate 0 packets/sec
clu# sh logging last 2
2014 Jan 22 14:00:03 clu %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by su on 109.1.19.
125@pts/2
2014 Jan 22 14:01:10 clu last message repeated 1 time
Cannot find any hints to "Hardware prog failed"
Amit Singh
Hi Holger,
Please attach using the insert image option on the reply window. It should be on the top next to bullet and numbering option. If you want, send me an email at amisin@gmail.com.
Cheers,
-amit singh
7 Replies 7
Amit Singh
Holger,
How does the config looks like on your boxes? Are you using a lot of ACL's?
Could you paste the output of "Show system internal access-list resource utilization" ?
Do you have some tunnel debugs as well?
Cheers,
-amit singh
there are only a few (8) ACL's configured.
Output from Show system internal access-list resource utilization:
slot 2
INSTANCE 0x0
         ACL Hardware Resource Utilization (Mod 2)
                         Used   Free   Percent
                                         Utilization
Tcam 0, Bank 0           1       16383   0.01
Tcam 0, Bank 1           2       16382   0.01
Tcam 1, Bank 0           154     16230   0.94
Tcam 1, Bank 1           201     16183   1.23
LOU                       2       102     1.92
Both LOU Operands         0
Single LOU Operands       2
LOU L4 src port:         1
LOU L4 dst port:         1
LOU L3 packet len:       0
LOU IP tos:               0
LOU IP dscp:             0
LOU ip precedence:       0
LOU ip TTL:              0
TCP Flags                 1       15     6.25
Protocol CAM             4       3       57.14
Mac Etype/Proto CAM       0       14     0.00
Non L4op labels, Tcam 0   0       6143   0.00
Non L4op labels, Tcam 1   4       6139   0.06
L4 op labels, Tcam 0     0       2047   0.00
L4 op labels, Tcam 1     2       2045   0.09
Ingress Dest info table   1       511     0.19
Egress Dest info table   0       512     0.00
slot 4
INSTANCE 0x0
         ACL Hardware Resource Utilization (Mod 4)
                         Used   Free   Percent
                                         Utilization
Tcam 1, Bank 0           321     16063   1.96
LOU                       3       101     2.88
Both LOU Operands         1
LOU L4 src port:         1
LOU L4 dst port:         1
LOU IP tos:               0
LOU IP dscp:             0
LOU ip TTL:               0
TCP Flags                 1       15     6.25
Protocol CAM             7       0       100.00
Non L4op labels, Tcam 1   2       6141   0.03
L4 op labels, Tcam 1     3       2044   0.14
slot 5
NOT Supported in SUP ACLQOS
slot 6
slot 7
INSTANCE 0x0
         ACL Hardware Resource Utilization (Mod 7)
                         Used   Free   Percent
                                         Utilization
LOU                       3       101     2.88
Both LOU Operands         1
LOU L4 src port:         1
LOU L4 dst port:         1
LOU IP tos:               0
LOU IP dscp:             0
LOU ip TTL:               0
TCP Flags                 1       15     6.25
slot 9
INSTANCE 0x0
         ACL Hardware Resource Utilization (Mod 9)
                         Used   Free   Percent
                                          Utilization
Tcam 1, Bank 0           150     16234   0.92
LOU                       2       102     1.92
Both LOU Operands         0
LOU L4 src port:         1
LOU L4 dst port:         1
LOU IP tos:              0
LOU IP dscp:             0
LOU ip TTL:               0
TCP Flags                 1       15     6.25
Cheers,
Holger
Hi Holger,
Check this, we have different internal protocols and looks like its been utilized 100%
Please can you "show system internal access-list input entries "
Capture the above output in one file
And in another file
"show system internal access-list input entries detail"
An L4 protocol entry refers to an ACE that matches a specific L4 protocol
number like TCP, UDP, ICMP, OSPF, etc... The N7k (at least for M1 modules)
can match against a fixed number of user defined L4 protocols. Software
maintains a list of entries on a per module basis. These entries are shared
by all ACLs on the module between each VDC for input and output ACLs. In
other words, each module has a fixed number of indexes that is shared
between all VDCs in the system. Different modules can maintain different
indexes depending on what features are applied.
Currently there is a maximum of 7, L4 protocols that can be dynamically
allocated.
We have the following protocols
112 - VRRP
53 - SWIPE
55 - MOBILE
77 - SUN-ND
51 - AH
88 - EIGRP
89 - OSPFIGP
All of this has been utilized by access list and qos policies applied
What we should do now is , review the ACL applied and remove a few entries that match the above protocol number.
Or use any other way to match the same traffic -
For example
IP access list VRRP
permit 112 any 224.0.0.0/24
IP access list PIM
permit ahp any 224.0.0.13/32
to:
IP access list VRRP
permit ip any 224.0.0.18/32
IP access list PIM
permit ip any 224.0.0.13/32
Hope this helps.
Cheers,
-amit singh
Hi Amit,
I got the outputs from both commands. I wonder if you can see anything out of it. How can I add these file to this forum (it' s the first I am using it ;-)
Cheers,
Holger
Amit Singh
Hi Holger,
Cheers,
-amit singh
Hi Amit,
we changed the ACLs a bit, so "Protcol CAM" utilization is below 100 percent, but it is still impossible to configure tunnel interface. Any other ideas?
Cheers,  Holger
after sub switchover (and back) problem is solved
