Nexus 9000 FC to Dell Unity ARBFF Issue
leighharrison
Level 7
Level 7
Hi there,
On Friday we swapped out an old N5k for a new N9k, all config alterations were made and the switches were swapped out. Everything worked fine, except for the 4 x 8G FC interfaces that connect to a Dell Unity, they went into errdisable complaining that it had received ARBFF (arbff fill-pattern rcvd from peer)
I tried forcing the interface to ARBFF but it looks like it’s not supported on 8G interfaces. Nothing I tried seemed to help and the Unity doesn’t have any options in the GUI that we could see to change to IDLE.
Has anyone seen this? What’s the fix?
Best, Leigh
Kirk J
Greetings.
There was a bug filed for your general scenario, https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvm09149
Kirk...
leighharrison
Level 7
Level 7
Hi there,
After going through it with TAC, there seems to be no plan to support ARBFF on 8Gbps.
Fixes are either drop to 4Gbps or go up to 16Gbps, it’s peculiar to 8Gbps only. We went for 4Gbps initially as we had the SFP’s knocking about, then got some 16Gbps ones. All is fine now.
Best, Leigh
