Not enough memory space on Cisco MDS Switch
amaingi
On running the cmd:
show tech-support > bootflash:TechSupport.txt
on a Cisco MDS 9700 series switch, it shows
write error: no space left on the device.
Following are the various command results:
How can I resolve it?
show system internal flash
Mount-on                  1K-blocks      Used   Available   Use%  Filesystem
/proc                             0         0           0      0   proc
/sys                              0         0           0      0   none
/isan                       2097152    831332     1265820     40   none
/var                          51200       668       50532      2   none
/nxos/tmp                     51200      1104       50096      3   none
/var/log                      51200       972       50228      2   none
/var/home                      5120         0        5120      0   none
/var/tmp                     307200       284      306916      1   none
/var/sysmgr                 2097152       156     2096996      1   none
/var/sysmgr/ftp             1048576    195308      853268     19   none
/var/log/fw                 1048576         0     1048576      0   none
/var/sysmgr/srv_logs         307200         0      307200      0   none
/var/sysmgr/ftp/debug_logs    102400         0      102400      0   none
/dev/shm                    1572864    288488     1284376     19   none
/dev/icam                    524288         0      524288      0   none
/volatile                   1048576         0     1048576      0   none
/debug                         2048        12        2036      1   none
/dev/mqueue                       0         0           0      0   none
/debugfs                          0         0           0      0   nodev
/mnt/plog                    238334      2993      222824      2   /dev/sdb1
/mnt/fwimg                   117123        31      110833      1   /dev/sdb3
/mnt/cfg/0                    71701       577       67210      1   /dev/sda5
/mnt/cfg/1                    71701       577       67210      1   /dev/sda6
/logflash                  15464836    110844    14566744      1   /dev/sdc1
/bootflash                  3620400   2323188     1111640     68   /dev/sda3
/cgroup                           0         0           0      0   vdccontrol
/var/sysmgr/startup-cfg      409600      6624      402976      2   none
/dev/pts                          0         0           0      0   devpts
/mnt/pss                      34060      3171       28919     10   /dev/sda4
/smack                            0         0           0      0   smackfs
/sys/kernel/security              0         0           0      0   securityfs
/proc/fs/nfsd                     0         0           0      0   nfsd
/bootflash_sup-remote       3620400   3382600       52224     99   127.1.1.5:/bootflash/
/logflash_sup-remote       15261600    833632    13646040      6   127.1.1.5:/logflash/
show system internal dir /var/sysmgr/ftp
        ./         600
                                                               ../         360
                                                   lc_patch.slot9@          15
                                                   lc_image.slot9@           9
                                                lc_boot.nbi.slot9@          19
                                                   lc_patch.slot4@          15
                                                   lc_image.slot4@           9
                                                lc_boot.nbi.slot4@          18
                                                  lcf32.bin.patch/          40
                                                        lcf32.bin     30286531
                                         base_p476_boot.nbi.patch/          40
                                               base_p476_boot.nbi     38982144
                                              lcfln_mds.bin.patch/          40
                                                    lcfln_mds.bin     21052299
                                                  lctsh.bin.patch/          40
                                                        lctsh.bin     22713921
                                              base_p8572_boot.nbi     36633600
                                                   lc2dce_mds.bin     15780303
                                                  lc4xb.bin.patch/          40
                                                        lc4xb.bin     17091335
                                        base_p8541_boot.nbi.patch/          40
                                              base_p8541_boot.nbi     17331712
                                               lc_max_allowed_vdc            1
                                                            cores/          40
                                                  plugin_swid_map         4156
                                                  pss_helper.4403/          40
                                                  pss_helper.4414/          40
                                                        rev-gsync/          60
                                                       debug_logs/          40
                                                         img-sync/         140
show system internal dir /var/tmp
        ./        1480
                                                               ../         380
                                                 cert_en_cert.tar        30720
                                          snmpd_ld_dbg_trans.4548          967
                                            lcdc3_syncpoint4.5537          524
                                            lcdc3_syncpoint5.5528          953
                                                           arping           99
                                                       remote_srg          496
                                                   cmp.log.5332.0          201
                                                fcoe_mgr_init.log        15506
                                                         fcoe_mgr            0
                                                  fc-pcm-log-5314        11317
                                             ilc_helper_issu_logs            0
                                                diag_port_lb.5260            0
                                                        PIXMC_LOG           48
                                                   nginx_1-p.conf         2946
                                                  nginx_1-b4.conf          853
                                                  nginx_1-b3.conf          853
                                                  nginx_1-b2.conf          853
                                                  nginx_1-b1.conf          853
                                                      nginx_local/         120
                                                          nginx_1@          15
                                            lcdc3_syncpoint3.4720         4573
                                            lcdc3_syncpoint2.4719         4009
                                                      usd_pss_3f2         1446
                                                      usd_pss_4ed         1450
                                                     clpl3usd.log            0
                                                      usd_pss_1a6          583
                                                      usd_pss_285         2283
                                                      usd_pss_309         1410
                                                  SAC_LIBRARY.log          206
                                                        clm_clp_4            0
                                                      usd_pss_2f6         1853
                                                      usd_pss_306         1437
                                                      usd_pss_30d         1434
                                                  clp_elam_ip.log            0
                                               clp_elam_debug.log            0
                                                     clp_elam.log         3200
                                            lcdc3_syncpoint1.4709          524
                                                     xbm-log-4678         9553
                                                           ntpd_1            0
                                                     ntp_client_1            0
                                                  security_stderr           86
                                                  security_stdout            0
                                                    keystore_type            1
                                               security_debug.log          847
                                                fwimg_extract.log          388
                                                      mts_pss.log         3925
                                                    cmp_slot_id.5            0
                                                   vshddebugcheck            0
                                                        lockcisco            0
                                                          .flexlm/          60
                                       sysmgr_startcfg_flash.lock            0
                                                       pfm_loader          130
                                                             pfm0        10389
                                                        pfm_dummy          910
                                                             logs@          20
                                                   boot-debug.log           51
                                                 mts_opc_load.log          815
                                                   nginx_loopback           30
                                       pend_activated_patch_files           29
                                            committed_patch_files           29
                                         issu_deact_pend_files_cm           43
                                         issu_deact_pend_files_ac           43
                                              issu_act_pend_files           38
                                                    nginx-dm.conf@          32
                                                         nginx-dm@          15
                                          non_inactive_patch_list            0
                                                code_coverage.log          392
                                                            mysrg         2304
                                                     log_flashlog           12
                                               flash-err-log-file           12
                                                  boot_uptime.log         1905
                                                              vsh/          40
show cores
Module  Instance  Process-name     PID       Date(Year-Month-Day Time)
jihicks
Looking at this I see that bootflash: is 68% full on the active sup and 99% on the standby sup.
You can see what is using this space ( I suspect old versions of firmware or configuration backups ) by doing:
dir bootflash:                                 <<<< active sup
dir bootflash://sup-remote/           <<< standby sup
You can delete unwanted files with:
delete bootflash:<filename>
delete bootflash://sup-remote/<filename>
Do not delete the kickstart and system image form the current running version.
Best regards,
Jim
