Cisco HX use Ethernet port 1 G for DMZ
lamsarr
Hi Makus,
I have a question.
In my architecture (3 nodes cisco HX C240c M5) + 2 UCS FI 6248up interconnected on my cisco switch Catalyst backbone. All my equipments are interconnected by SFP+ 10G (HX-node ---> Cisco FI ---> Backbone Cisco Catalys)
And I have 4 vlans in my Data Center.
50 hx-inband-mgmt
100 hx-storage -network
200 hx-vmotion
(40, 300) vm-network
Now I want add a network bridge between my HX-node and my Palo Alto Firewall to connect on my Public DMZ.
I want use the both 1G Ethernet ports on my HX-Node by node to connect that on the DMZ Switch. But in FI KVM console on my nodes I don’t find my Ethernet vmnic. How can I discover my both Ethernet ports in my VMware ESXi?
Best regards,
Jaderson Pessoa
It is necessary turn on your interface, check the link below to help you.
https://kb.vmware.com/s/article/2006074?lang=en_US
If necessary, create a vswitch to has better management.
https://support.sonus.net/display/DSCDOC161/Creating+a+Virtual+Switch+in+VMware+ESXi
Regards.
Jaderson Pessoa
*** Rate All Helpful Responses ***
lamsarr
50 hx-inband-mgmt
200 hx-vmotion
Now I want add a network between my HX-node and my Palo Alto Firewall to connect on my Public DMZ.
Instead of using  both 1G ports I had add a link between my fabrics and the Palo firewall to 10G link.
To do this i :
- connecte fabirc to Palo
- enble a uplink port,
- create a vlan400,
- make NIC9 and NIC10 of my servers node to vlan400
But when i associate vlan400 to uplink port i have a indicate error (ether VIF x / xxx down, reason: ENM source pinning failed”) in Vlan on UCSM.
Could you guide me to create this link to FIs and Palo Firewall?
Best regards,
