NSS 322 power flashing red
isatelgroup12
Hello, I have a NSS322, I had to change a hard drive, because it was damaged. When it came again, I tried to use the setup wizard but it can not find the device and the power button shows a flashing red light, but I can login to the panel settings and the logs shows a warning that says:
"[Mirror Disk Volume: Drive 2] RAID device in degraded mode". According to what I read it means that there are problems with the hard drive, but the status of the hard drives both say good and ready, I formated and scan to look for bad sectors, but all goes well.
Is there any way to fix this?
Thanks for your help.
blissfieldmfg
I am having the same issue.  Have you had any luck fixing the problem?
I went into the configuration panel and verified if it was raid 1, then I configured again the hard drives and It worked. I hope it works for you too.
