Creating storage vdc on 7k (fcoe)
domstevens
Can I have some help with the following
I have a 7k -and when doing
conf t
vdc my-store-fcoe type storage
I get the following -
Note: Creating VDC, one moment please ...
Then 15 Minutes later -
Note: FCoE Enable failed
ERROR: VDC action failed, Cleaned up ungracefully
Any suggestions welcome
Best regards
PS
I would also like to know how I can check the license and the gracetime for Fcoe ?
Hi Dominic
I know this not gonna help you, but I faced the same problem and it was solved by enabling the system qos.
license fcoe module 7
install feature-set fcoe
system qos
  service-policy type network-qos default-nq-7e-policy
vdc FCOE id 4 type storage
  limit-resource module-type f1
  allow feature-set fcoe
Cheers
Kenneth
5 Replies 5
Prashanth Krishnappa
Hello Dominic
Do you have the QoS enabled? If not, you will need this service-policy under system qos
N7K-24-12-7010-1# sh run ipqos
!Command: show running-config ipqos
!Time: Thu Jun 28 08:17:43 2012
version 5.2(4)
system qos
This is how you check for licenses
N7K-24-12-7010-1# sh license usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
MPLS_PKG                      No    -   Unused             -
STORAGE-ENT                   Yes   -   Unused Never       -
ENTERPRISE_PKG                No    -   Unused             -
FCOE-N7K-F132XP               Yes   1   Rsrved Never       -
ENHANCED_LAYER2_PKG           Yes   -   In use Never       -
SCALABLE_SERVICES_PKG         No    -   Unused             -
TRANSPORT_SERVICES_PKG        Yes   -   Unused Never       -
LAN_ADVANCED_SERVICES_PKG     Yes   -   In use Never       -
LAN_ENTERPRISE_SERVICES_PKG   Yes   -   In use Never       -
So we have checkd and confirmed the licensing and qos is all good -
But the storage vdc created still fails after a 10-15 min wait
2012 Jul 12 17:18:46 AS-7010-1 %VDC_MGR-5-VDC_STATE_CHANGE: vdc 4 state changed to create in progress
2012 Jul 12 17:29:08 AS-7010-1 %VDC_MGR-3-VDC_ERROR: vdc_mgr: There has been a failure while enabling FCoE
2012 Jul 12 17:29:08 AS-7010-1 %VDC_MGR-5-VDC_STATE_CHANGE: vdc 4 state changed to delete in progress
2012 Jul 12 17:29:08 AS-7010-1 %VDC_MGR-3-VDC_ERROR: vdc_mgr: A sequence has timed out!
2012 Jul 12 17:29:08 AS-7010-1 %SYSMGR-3-SHUTDOWN_START: The System Manager has started the shutdown procedure.
2012 Jul 12 17:29:08 AS-7010-1 %SYSMGR-2-SHUTDOWN_SYSTEM_LOG: vdc 4 will shut down soon.
2012 Jul 12 17:29:08 AS-7010-1 %SYSMGR-STANDBY-3-SHUTDOWN_START: The System Manager has started the
shutdown procedure.
2012 Jul 12 17:29:08 AS-7010-1 %SYSMGR-STANDBY-2-SHUTDOWN_SYSTEM_LOG: vdc 4 will shut down soon.
2012 Jul 12 17:29:09 AS-7010-1 %VDC_MGR-2-VDC_OFFLINE: vdc 4 is now offline
Can someone help with suggestions or lookup in bugtrack
Cheers
Dominic
Hi Dominic
system qos
Cheers
Kenneth
thanks a lot guys for this post...it really saved my time.
Zulfi
Dominic,
Please post "show ver" and "show run" and I will have a look.
Anthony
