Opening java DCNM SAN app cert problems
steve switzer
When i try and open the cisco dcnm san java app it asks me to run the application comes up with 'more information' on the bottom left hand corner
which if i open it says 'the applications associated file jlnp does not have an associated signature' now while the app still opens i foresee this being a problem.
I am on java release 1.7.0_72
I have tried a few things none of which have worked so far
Any ideas
Steve
jihicks
Hi Steve,
You did not mention what version of DCNM you are using.  You might be hitting a problem where the older versions of DCNM-SAN were created to use Java 1.5 or 1.6. If you run them with Java 1.7 the certificate is expired or maybe unrecognized.  You can download a more current client from Cisco Online, such as 6.3(2):
DCNM 6.3.2 San Client Package
dcnm-san-client.6.3.2.zip
Data Center Network Manager-6.3(2)
Best regards,
Jim
