password recovery for mds
sarcher
I have never worked on a MDS switch and I am tasked with password recovery on a mds9216. Please clarify the following step outlined in the recovery document. What command will I use from the switch(boot)# to find the correct file to load?? I am thinking
dev
dir flash
switch(boot)#load bootflash:san-ios.img
tblancha
It would be dir bootflash: and the load command would work only san-ios.img is there. More than likely it looks more like this format: m9200-ek9-mz.2.1.2e.bin
But, yes, you have it in a nutshell. This is a sample of what it looks like if you don't have a SAN-OS on the bootflash:
Switch(boot)# config t
Switch(boot)(config)# interface mgmt 0
Switch(boot)(config-mgmt0)# ip address 172.18.172.57 255.255.255.0
Switch(boot)(config-mgmt0)# no shut
Switch(boot)(config-mgmt0)# exit
Switch(boot)(config)# ip default-gateway 172.18.172.1
Switch(boot)(config)# exit
Switch(boot)# copy tftp:m9500-sf1ek9-mzg.1.2.0.96.bin bootflash:m9500-sf1ek9-mzg.1.2.0.96.bin
Switch(boot)# load bootflash:m9500-sf1ek9-mzg.1.2.0.96.bin
Thanks. I am starting a new job with a consulting company called Xtira which archives paper/xray documents into a SAN for Hospitals. I will be conducting surveys to support the archive process. Can you direct me to a white paper which outlines Cisco SAN design/deployment.
Thank-you,
Steve
Hi steve,
There is a document for CISCO -SAN Design,
just go thro,
http://www.cisco.com/en/US/products/ps5990/products_white_paper0900aecd8044c807.shtml
Rgs.
