Port-Channel issue between UCS FI and MDS 9222i switch
sultanshaikh5
I have a problem between UCS FI and MDS switch port-channel. When MDS-A is powered down the port-channel fails but UCS blade vHBA does not detect the failure of the port-chanel on UCS-FI and leaves the vHBA online. However, if there is no port-channel between FI-->MDS it works fine.
UCS version
System version: 2.0(2q)
FI - Cisco UCS 6248 Series Fabric Interconnect ("O2 32X10GE/Modular Universal Platform Supervisor")
Software
  BIOS:      version 3.5.0
  loader:    version N/A
  kickstart: version 5.0(3)N2(2.02q)
  system:    version 5.0(3)N2(2.02q)
  power-seq: Module 1: version v1.0
             Module 3: version v2.0
  uC:        version v1.2.0.1
  SFP uC:    Module 1: v1.0.0.0
MDS 9222i
Software
  BIOS:      version 1.0.19
  loader:    version N/A
  kickstart: version 5.0(8)
  system:    version 5.0(8)
Here is the config from MDS switch
Interface  Vsan   Admin  Admin   Status          SFP    Oper  Oper   Port
                  Mode   Trunk                          Mode  Speed  Channel
                         Mode                                 (Gbps)
fc1/1      103    auto   on      trunking         swl    TF      4    10
fc1/2      103    auto   on      trunking         swl    TF      4    10
fc1/9      103    auto   on      trunking         swl    TF      4    10
fc1/10     103    auto   on      trunking         swl    TF      4    10
This is from FI.
                         Mode                                 (Gbps)
fc1/29     103    NP     on      trunking         swl    TNP     4    103
fc1/30     103    NP     on      trunking         swl    TNP     4    103
fc1/31     103    NP     on      trunking         swl    TNP     4    103
fc1/32     103    NP     on      trunking         swl    TNP     4    103
Any thoughts on this?
padramas
Sultan,
This is a recently found issue and is fixed in UCSM 2.0.3a version .
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCua88227
which got duped to  CSCtz21585
It happens only when following conditions are met
FI in End host mode
FC uplinks are configured for portchannel + trunking
Certain link event failures ( such abrupt power loss by upstream MDS switch )
Padma
