08-13-2012 11:14 PM
Hello All,
I am experiencing a problem while trying to create port-channel interface. The interface did not come up. If i look at the
show interface port-channel ,
c5548p-3# show interface port-channel 1
port-channel1 is down (BPDUGuard errDisable)
Hardware: Port-Channel, address: 0000.0000.0000 (bia 0000.0000.0000)
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec
Encapsulation ARPA
Port mode is trunk
auto-duplex, 10 Gb/s
Input flow-control is off, output flow-control is off
Switchport monitor is off
EtherType is 0x8100
Members in this channel: Eth1/17
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
0 unicast packets 163 multicast packets 0 broadcast packets
163 input packets 19383 bytes
0 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 unicast packets 576 multicast packets 89 broadcast packets
665 output packets 84347 bytes
0 jumbo packets
0 output errors 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
1 interface resets
Not sure what is causing this error. Could any one please throw some light how to fix this?
08-13-2012 11:16 PM
Adding few more information
It is a c5548p switch with fimware 5.2(1)N1(1)
08-14-2012 03:34 AM
without the configuration of the prot hard to say BPDUGuard is enabled when a port is is portfast mode. The port then shuts down when a BPDU is received. What is at the other end of the port-channel?
