port-channel1 is down (BPDUGuard errDisable)
niranjandas
Hello All,
I am experiencing a problem while trying to create port-channel interface. The interface did not come up. If i look at the
show interface port-channel ,
c5548p-3# show interface port-channel 1
  Hardware: Port-Channel, address: 0000.0000.0000 (bia 0000.0000.0000)
  MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, 10 Gb/s
  Input flow-control is off, output flow-control is off
  Switchport monitor is off
  EtherType is 0x8100
  Members in this channel: Eth1/17
  30 seconds input rate 0 bits/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    0 unicast packets  163 multicast packets  0 broadcast packets
    163 input packets  19383 bytes
    0 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 unicast packets  576 multicast packets  89 broadcast packets
    665 output packets  84347 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
  1 interface resets
Not sure what is causing this error. Could any one please throw some light how to fix this?
niranjandas
Adding few more information
It is a c5548p switch with fimware 5.2(1)N1(1)
without the configuration of the prot hard to say BPDUGuard is enabled when a port is is portfast mode. The port then shuts down when a BPDU is received. What is at the other end of the port-channel?
