Power off and power on a Cisco Switch
victorm.munoz
Hello guys
this is my first thread
Due a maintenance, we need to turn off for some hours our cisco MDS 9500 switches.
Does anyone have all steps needed to do this in a graceful way?
I've never needed to do this and want to take all precautions and preserve all active configurations after the power up
Thanks in advance
dynamoxxx
Level 5
Level 5
save running config to startup config and then ftp/sftp to an external location. There is no shutdown command per say, just flip the switches on power supplies.
@dynamoxxx
@dynamoxxx
dynamoxxx
Level 5
Level 5
@dynamoxxx
@dynamoxxx
Thanks for your response dinamoxxx
I ran the command in one switch:
SWITCHHOSTNAME# copy running-config startup-config
[########################################] 100%
Just another question, why there is a command called "poweroff module", what is it used for?
-Victor
to poweroff individual modules, other then to poweroff and replace specific modules i have not idea why someone would use it.
@dynamoxxx
@dynamoxxx
Leo Laohoo
To "gracefully" shutdown a chassis-based switch, you do the following:
1.  Console into the switch;
2.  Save your config locally (and/or remotely);
3.  Issue the "reload" command and hit "enter"; and
4.  As soon as the console stops working, power down the chassis.
