Proper steps for reconfiguring FCIP tunnel
tom.duong
Hi - I have an active FCIP pipe that is running without compression and write acceleration. I'd like to experiment with these features. How should I go about activating these features. Do I need to down the fcip2 interface on both 9216i first or can I leave the interface up and just activate these features? Thanks a bunch!
tblancha
Compression can be enabled on the fly w/o disabling anything. However, the FC-WA will move the virtual FCIP interface down. Go ahead and do both sides and then re-enable the fcip interfaces. Be sure to check your replication schema is certified-IE, make sure FC-WA works for your traffic. Roughly speaking, The gain of using compression typically is lost when you are using over 45M of traffic.
tblancha
mrfrase
Also, to help in your testing you can display the compression stats with
One of the good guides to also follow is found at http://www.cisco.com/application/pdf/en/us/guest/netsol/ns378/c649/cdccont_0900aecd800ed146.pdf
