Question for transit vsan
steven.li
I had below configurations at my Cisco switches:
1. Cisco switch 1:vsan 1 and vsan9
2. Cisco switch 2:vsan 1 and vsan9
Vsan1 of switch1, operation of all ports:notrunk,  vsan9 of switch1, operation:trunk, the port is trunking and connected to switch2 vsan9
Vsan1 of swtich2, operations of all ports, notrunk. vsan9 of switch2, operation:trunk, the port is truning and connected to switch1 vsan9
As my understanding vsan9 is transit vsan for these 2 switch, how about vsan1? is it a transit vsan also? And do we have a CLI command to identify the transit vsan?
Thanks in advance for your answer.
Walter Dey
Hi Steven
VSAN 1 is very Special, and should never be used for operational purposes. same applies btw. for vlan 1 ! Every FC, FCoE interface by default is in VSAN 1.
Transit VSAN's are usually used
- when 2 sites are linked with FC, and a fabric merge is not desired !
- IVR is therefore used to route between each site and the transit VSAN.
see eg.
https://www.experts-exchange.com/questions/24740659/IVR-transit-VSANs-Cases-for-use.html
http://blog.scottlowe.org/2011/07/14/brksan-3707-advanced-san-services/
https://community.emc.com/thread/205217?tstart=0
p 180ff in https://www.emc.com/collateral/hardware/technical-documentation/h8074-fibre-channel-san-tb.pdf
Walter.
