questions about smart zone limitations
Ahmed Abdullahi
Hi everyone, I had a couple of questions regarding smart zone limits:
  1. what is the problem with more than 50 members in a smart zone?
  2. what is the problem with multiple initiators in a smart zone?
  3. What happens if I have more than 128 hosts per target?
https://www.cisco.com/c/en/us/support/docs/storage-networking/zoning/116390-technote-smartzoning-00.html
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/sw/7_3/configuration/config_limits/b_mds_9000_configuration_limits_7_3.html
Ahmed Abdullahi
I found the answer to the question about zones with more than 50 members .  There is no problem with having zones with more than 50 member.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCur12442/?referring_site=bugquickviewredir
gautam.verma1
To avoid below  warning
WARNING: The specified zoneset has 4 zone(s) with more members than the recommended limit (50) Zoneset activation initiated. check zone status.
fcalias name xxx_xxx_hosts vsan 10
member device-alias xxx-xxx-xx initiator
exit (Exit is must required before zoneset activate, it will eliminate the above warning)
ACS
