san-port-channel imcompatible
IBMsupport123
I have a question for folks.
I'm getting the following error
N5k-1(config)# interface san-port-channel 20
N5k-1(config-if)# sw mode f
error: incompatible port mode config type (0x40290027)
I tried to set "F" because f1/43, f1/44 are facing to Storage and type f.
NADC1301NN5K01MM7(config-if)# sho int fc1/43 | in mode
    Admin port mode is auto, trunk mode is auto
    Port mode is F, FCID is 0x240040
NADC1301NN5K01MM7(config-if)# sho int fc1/44 | in mode
    Port mode is F, FCID is 0x240060
Is this not supported ?
N5k-1(config-if)# sho version | in version
  BIOS:      version 3.6.0
  loader:    version N/A
  kickstart: version 5.2(1)N1(1b)
  system:    version 5.2(1)N1(1b)
  power-seq: Module 1: version v5.0
  uC:        version v1.0.0.2
  System version: 5.1(3)N2(1b)
samky2005
Jeremy Waldrop
Level 4
Level 4
Do you have the fport-channel-trunk feature enabled? This is needed to create put a SAN Port Channel into F mode.
