SAN - Storage
Toss Leey
Hello Genius
I have following SAN storage:
-6 blade server UCS B200 M4 in 5108 chassis with two UCS 6248UP,
Can I increase the capacity of storage up to 45 TB without buy another chassis, what's is the best solution..
2 Accepted Solutions
Walter Dey
I assume you mean external storage, not local storage on the blade ?
Yes ! there are 2 choices: either connecting a storage Subsystem directly to UCS fabric interconnect, or connect storage Subsystem by means of a SAN to the fabric interconnect.
Walter.
There will be 3 choices (soon !)
- Cisco storage blade in a UCS Chassis (this is SSD based); available soon.
- certified storage subsystems (e.g. Netapp, HDS, EMC,..) connected directly to fabric interconnect (no Connection to fex)
-Storage Subsystems (Netapp, EMC, HDS, IBM,....) connected via SAN to fabric interconnect
Walter Dey
Walter.
Hi Walter
storage subsystem like another blade server with chassis?, also should i connect
storage subsystem directly to fabric interconnect or fabric extender?
