Nexus 5548 "show interface" output: difference between "input" and "jumbo" packet counters?
noemi.berry
In "show interface" output on a Nexus, both "input packets" and "jumbo" counters are given, and they're different.  What do they mean?  Does the input packets counter mean ALL packets, including jumbo?  What is the threshold between "input" and "jumbo"?
The interface is configured for MTU 9216, but displays MTU 1500.   I'll guess that the "input" counter means frames sized 64 - 1500, and "jumbo" means 1501 - 9216, but there's no indication that 1500 is anything more than a display error.
Also, is the "input" counter inclusive of the "jumbo" count?
Nexus5548# show int eth1/30
Ethernet1/30 is up
  Hardware: 1000/10000 Ethernet, address: 547f.eec7.b7e5 (bia 547f.eec7.b7e5)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 507.95 Mbps, 55.41 Kpps; output rate 52.67 Mbps, 41.48 Kpps
  RX
    1211570942425 unicast packets  1493668 multicast packets  2181 broadcast packets
    1211572438274 input packets  1297260294121170 bytes
    606942154661 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    963058213408 unicast packets  2496305921 multicast packets  165929356 broadcast packets
    965720448685 output packets  195031410581408 bytes
    34410403264 jumbo packets
    18 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
Nexus5548# show queuing int eth1/30
Ethernet1/30 queuing information:
  TX Queuing
    qos-group  sched-type  oper-bandwidth
        0       WRR            100
  RX Queuing
    qos-group 0
    q-size: 470080, HW MTU: 9216 (9216 configured)
    drop-type: drop, xon: 0, xoff: 470080
    Statistics:
        Pkts received over the port             : 390178800
        Ucast pkts sent to the cross-bar        : 390007564
        Mcast pkts sent to the cross-bar        : 171236
        Ucast pkts received from the cross-bar  : 849647150
        Pkts sent to the port                   : 1045944237
        Pkts discarded on ingress               : 0
        Per-priority-pause status               : Rx (Inactive), Tx (Inactive)
Thanks!
noemi.berry
Found the answer.
Anatomy of RX packet counters on a Cisco Nexus 5548:
Nexus5548# show int eth1/29
  RX
    6387682660 unicast packets  1495485 multicast packets  164 broadcast packets
    6389178309 input packets  589693485138 bytes
    5146969 jumbo packets  0 storm suppression bytes
  * "input" = unicast + multicast + broadcast (all non-jumbo)
  * "jumbo" = frames sized 1519 bytes to the MTU bytes defined on the interface
  * "jumbo" frames are counted separately from non-jumbo ("input")
  * (unicast, multicast and broadcast "jumbo" frames appear to be rolled into the
        one "jumbo" counter)
This can be seen another way with the 'count detail' command, correlated to "show int" output:
Nexus5548# show int eth1/29 count detailed
Ethernet1/29
  Rx Packets:                                  6389178309 <-- input
  Rx Unicast Packets:                          6387682660 <-- unicast
  Rx Multicast Packets:                           1495485 <-- multicast
  Rx Broadcast Packets:                               164 <-- broadcast
  Rx Jumbo Packets:                               5146969 <-- jumbo
  Rx Bytes:                                  589693485138
  Rx Packets from 0 to 64 bytes:                  1059418 <-- non-jumbo start
  Rx Packets from 65 to 127 bytes:             6072007478       +
  Rx Packets from 128 to 255 bytes:              11055520       +
  Rx Packets from 256 to 511 bytes:             287107435       +
  Rx Packets from 512 to 1023 bytes:             12801466       +
  Rx Packets from 1024 to 1518 bytes:                  23 <-- non-jumbo end
  Rx Trunk Packets:                            6387682823 <-- unicast + broadcast
fyi.
