Scripting
User_4444_2
Level 3
Level 3
I want to use "cli var" command to setup a variable for the sh clock command, "cli var name time sh clock".
So I can run a script and use the variable to add the output of sh clock to "copy run tftp://10.*.*.*/Switch1A-$ time" so the sh clock would get added to the end of the file. I'm not a scripting person, so I might be talking rubbish.
dynamoxxx
Level 10
Level 10
how about you use built-in timestamp variable, like this:
copy startup-config tftp://192.168.1.7/switchA1.$(TIMESTAMP)
@dynamoxxx
dynamoxxx
Level 10
Level 10
@dynamoxxx
That did the trick.
