Renaming Zonset basics
planzone
Greetings all,
If I wanted to rename our active zonset called abc vsan 21 to xyz vsan 21 on our 9500 series mds. Doing this, should not cause an issue or knock anything offline?
A collegue of mine was telling me that it may knock its zones and members off line when I go to activate the new renamed zonset name. I thought it was simple as :
config t
then issue a zonset rename abc  <oldname>
then enter new name
then activate that new name
bamm done ?
Vu Phan
Here is what you will do
conf t
zoneset rename vsan xxx
zoneset activate name vsan xxx
exit
ex:
zoneset rename abc xyz vsan 21
zoneset activate name xyz vsan 21
This should not cause any disruption to traffic
