sensor_read_temp: failure reading temperature from sensor 0
Dinjamin1
I have a Temperature sensor driver error as follows:
2011 Mar 17 19:53:28 GB2FCC202EA %MODULE-4-MOD_WARNING: Module 12 (serial: JAF1435BFPG) reported warning due to Temperature sensor driver error in device 49 (device error 0xc310020b)
2011 Mar 18 03:09:15 GB2FCC202EA %PLATFORM-4-MOD_TEMPFAIL: Module-12 temperature sensor 1 failed
exception information --- exception instance 2 ----
Module Slot Number: 12
Device Id         : 49
Device Name       : Temperature-sensor
Device Errorcode  : 0xc310020b
Device ID         : 49 (0x31)
Device Instance   : 00 (0x00)
Dev Type (HW/SW)  : 02 (0x02)
ErrNum (devInfo)  : 11 (0x0b)
System Errorcode  : 0x00000046 Temperature sensor driver error
Error Type        : Warning
PhyPortLayer      : Fibre Channel
Port(s) Affected  : none
Error Description : sensor_read_temp: failure reading temperature from sensor 0
DSAP              : 0 (0x0)
UUID              : 0 (0x0)
Time              : Thu Mar 17 19:53:28 2011
                    (Ticks: 4D8258A8 jiffies)
Temperature:
Module   Sensor        MajorThresh   MinorThres   CurTemp     Status
                       (Celsius)     (Celsius)    (Celsius)
12       Outlet1         n/a             n/a         n/a        Failure
It looks a match for CSCsw41181 - however we don't see the following condition against any interface:
'Error disabled - SFP vendor not supported'
We tried reseating an SFP on this module but still no SFP vendor not supported condition.
Any other known bugs or do we have to treat it as a hardware issue?
thanks
kenk
If it is related to CSCsw41181, a reload of the module would clear the condition.
If you can schedule a maintenance window to reload the module, that may be the least
intrusive next step (keep in mind that reloading the module will be disruptive to all the ports
on that module).
Ken
