Nexus 5010 high Tx Pause
kshah2spires
I have a Server with Emulex OCE10102 CNA connected to Nexus 5010 I am seeing a very high "Tx Pause" on the Nexus side. Here is the output
sh int ethernet 1/8
Ethernet1/8 is up
  Hardware: 1000/10000 Ethernet, address: 000d.ecf5.bccf (bia 000d.ecf5.bccf)
  Description: *** AVAILABLE/SHUTDOWN ***
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 4/255, rxload 2/255
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s, media type is 10g
  Beacon is turned off
  Input flow-control is on, output flow-control is on
  Rate mode is dedicated
  Switchport monitor is off
  Last link flapped 07:38:24
  30 seconds input rate 877536 bits/sec, 495 packets/sec
  30 seconds output rate 243574056 bits/sec, 14850 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 108.71 Mbps, 6.93 Kpps; output rate 183.84 Mbps, 11.68 Kpps
  RX
    812395033 unicast packets  113123 multicast packets  0 broadcast packets
    812508156 input packets  1542522706844 bytes
    724639332 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    626577215 unicast packets  18338809 multicast packets  0 broadcast packets
    644916024 output packets  1066177460879 bytes
    498041692 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble
   15648457 Tx pause
  15 interface resets
Can someone suggest what could be the cause of high "Tx Pause". This is probably slowing down my server signficantly. I have updated the CNA with latest firmware
6 Replies 6
ddulek
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/troubleshooting/guide/n5K_ts_fcoe.htm
In the PCF section, it appears to be a flow control issue on that port on the switch.  I have a similar issue on a 5020 and have a TAC open.  It is "supposed" to pause when there is congestion but I do not think this server could be pushing 4 10G FCoE ports since the server it connect to is 1G and the storage is 4G.  If this was not a production server, I would probably test this:
Use the following commands under "interface ethx/y" to enable link pause instead of PFC with DCBX capable devices:
"no priority-flow-control mode on"
"flowcontrol receive on"
"flowcontrol send on"
Hi David
Good to know I am not the only one around. Yes I had gone through the document and had made the recommended changes. No change still
Vu Phan
The Tx pause from N5K means N5K try to send traffic to the other end, but the other side could not process fast enough. Thus N5K has to hold traffic.
Check the host side. If flowcontrol on, make sure it is on on both sides.
The understanding I have been given is that the Tx Pause is a pause requested by Cisco switch the client. The Rx Pause is a pause requested by the client.
In FCoE environment TX pause from N5k to the server might not be unexpected based on the environment. We will need trace between n5k switchport and CNA to determine what is going on.
Thanks, Vinayak
jeffreybunch
Did you ever find a resolution to this? I am working with my server folks and there is an indication of a possible bug with Emulex where there would be Frame Loss and Flow Control issues. I am wondering if this is the indicator. I have the same Emulex CNAs you mentioned connected to 2232 FEXs.
