show module internal exceptionlog
antonio_raldie
Hi all,
I just would like to ask help from anyone here in the forum. Here's the log or find attached.
`show module internal exceptionlog`
********* Exception info for module 1 ********
exception information --- exception instance 1 ----
Module Slot Number: 1
Device Id : 88
Device Name : XbarComplex
Device Errorcode : 0x00000003
Device ID : 00 (0x00)
Device Instance : 00 (0x00)
Dev Type (HW/SW) : 00 (0x00)
ErrNum (devInfo) : 03 (0x03)
System Errorcode : 0x40240019 Module asic(s) reported sync loss (DevErr is LinkNum). Trying to Resync
Error Type : Informational
PhyPortLayer : Fibre Channel
Port(s) Affected : 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16
Error Description :
DSAP : 0 (0x0)
UUID : 0 (0x0)
Time : Fri Feb 20 19:21:44 2009
(Ticks: 499F02C8 jiffies)
Is the module slot 1 and 7 needs replacement or just upgrading OS can do? Please need your advises regarding this.
Many thanks
Michael Brown
I suggest that you open a case with Cisco TAC on this. This could be either the modules, or one of the supervisors that are causing the sync loss. In either case, I doubt that it is software related. Let TAC review the error logs and make a suggestion.
- Mike
