SN5428 does not recognize Seagate ST39102FC JBOD
Alex1
When connected, displays (with logging on):
primaryPortLoginResp: PLOGI/PRLI failed status=0x6, loopId=0x81, portId=0x102e
1, plcPtr=0xd40aa88
Tried different FC port type settings (fl-port, gl-port, tl-port) with the same result.
What does the status=0x6 means? How to resolve the issue?
Alex
9 Replies 9
mrfrase
0x6 I believe is a Fibre Channel Timeout, disk is not responding
Have you tried placing the Drive in a diferent position in the JBOD?
Can you get a
Are there any other LUN's on the FC network?
There are 4 drives. I tried to place one of the drives in all four available positions. Also tried with all 4 LUNs in place. The only difference was that sometimes I'd get status=0x4007 and other times status=0x6.
Invariably, displays zero luns (here is an output):
[cisco5428]# show debug rawlundatabase all
Raw Lun Data Base for Interface fci1
Entry Address = 0xca71cd4
fabricLoginFailureCode=0x0,fabricLoginExtendedCode=0x0,fabricLoginTimeoutCode=0x0
ReportLunsLLDStatus=0x0,ReportLunsLLDStatusModifier=0x0,ReportLunsSCSIStatus=0x0,ReportLunsASCASCQ=0x0,ReportLunsLu
nCount=0
InquiryLLDStatus=0x0,InquiryLLDStatusModifier=0x0,InquiryLastLunWithLLDError=0x0,
InquirySCSIStatus=0x0,InquiryASCASCQ=0x0,InquiryLastLunWithSCSIStatusError=0x0
boolLunsNotSupported=0x0,InquiryLastLunNotSupported=0x0
loopId=0x7e,masterState=0x6,slaveState=0x7,loggedIn=1,roles=0,valid=1,portId=0xfffffe,scanLuns=0x0
numberLuns=0x0,reportAsyncEvent=0x0,node_wwn=0x10000009 0x7c604b41, port_wwn=0x20000009 0x7c604b41
Raw Lun Data Base for Interface fci2
Entry Address = 0xcdddb1c
nCount=0
numberLuns=0x0,reportAsyncEvent=0x0,node_wwn=0x10000009 0x7c604b41, port_wwn=0x200f0009 0x7c604b41
mrfrase
Yes, this output shows the SN5428 internal initiators in the SN5428 doing a query to the name server data base at FE but there are no devices in the databases reported. Looks like the target devices(LUNS) are not doing a FLOGI to the fabric switch now. On the first message in this post shows we are trying to log into Domain 01, port 02, device e1, which is not now in the nameserver.
Little to go on right now, may need to open a TAC case to really dig into what's going on.
Right now Alex is using a "passive" SFP-to-Fibre-Channel cable specifically purchased to setup this test bed. We have also unsuccessfully tried to connect the following with the same results:
(1.) JMR Fibre-Channel-over-copper JBOD (4 disk)
This JBOD is an older unit from 1998 with 4 fibre channel disks inside. We connected to the SN5428 via a passive SFP-to-FC9-Fibre-Channel cable, using FC9 Fibre-Channel terminators to cap the open FC9 connectors. No luck with this configuration, no LUN's are visable.
(2.) Second thing we tried was to connect a single Seagate ST39102FC Fibre-Channel hard disk directly to the SN5428. The connection was made via the same passive SFP-FC9-Fibre-Channel cable and a small Fibre-Channel Adapter that plugs directly on to the disk to accept FC9 connectors (one FC9 in and one FC9 out, we have the "out" side terminated with a standard FC9 terminator. No luck with this configuration either, no LUN's are visable.
- I'm starting to think this SN5428 wants to talk to some Arry logic, and not dumb JBOD's or disks directly. Where are we going wrong? Should we be able to talk directly to a Seagate ST39102FC disk directly?
Dan
We have labs full of the JMR Fortra copper enclosures with the Seagate FC drives. I have used the FC to DB9 Media converters on the JBOD's but they are very flaky at times. We also have used the copper SFP's that will take a direct H2FC to DBM cable that goes to the JBOD. The JBOD and drives will show up as a NL device. The Seagate FC imbedded controller on the drives will FLOGI into the Domain server in the SN5428. will show registered drives. If they do not FLOGI the SN5428 can not make them do it, no FC switch can make it FLOGI. Once the Nameserver is populated with the FCID's and pWWN of the Disk Drives the internal HBA's in the SN5428 will get database change notification and PLOGI to the Disks. At that point on the SN5428 will show the devices the internal HBA's tables have learned about on the Switch Fabric. will show any attempt from the Seagate FC drives to FLOGI into the network? If not it is a cable or drive issue.
This time we used Seagate ST39103FC, which shows up in the SN5428 compatibility matrix. The good news is that now we can see our drive in the fcswitch nameserver database:
0101e8 NL 1 21000020378707e4 00000000
At port 1, we see the wwpn of the drive.
It means FLOGI happened, and was sucessful. At this point we know it is not a cable issue.
But PLOGI still fails:
Jan 31 01:54:48: %FC-fci2-7-QPRBIOCB: plogiRsp: giving up! portId=0x101e8, wwpn=0x21000020378707e4, loginRetryCount=0x5, lldStatus=0x6, plc=0xcdd14b8
Jan 31 01:54:48: %FC-fci2-7-QPPLRPF: primaryPortLoginResp: PLOGI/PRLI failed status=0x6, loopId=0x81, portId=0x101e8, plcPtr=0xcdd14b8
As you can see, it is the same wwpn, so SN5428 was really trying (and failing with timeout) to contact our disk.
do a and then run
Mail the results to mfrase@cisco.com
Thanks.
Michael,
We definitely have some kind of configuration issue. I did as you said. Here's the printout:
*[cisco5428]# sh devices rediscover
Fibre channel discovery kicked off!
*[cisco5428]# Jan 31 04:18:38: %FC-fci2-7-QPRBIOCB: plogiRsp: giving up! portId=0x101e8, wwpn=0x21000020378707e4
, loginRetryCount=0x5, lldStatus=0x6, plc=0xcdd1430
Jan 31 04:18:38: %FC-fci2-7-QPPLRPF: primaryPortLoginResp: PLOGI/PRLI failed status=0x6, loopId=0x81, portId=0x1
01e8, plcPtr=0xcdd1430
Jan 31 04:18:38: %FC-fci1-7-QPRBIOCB: plogiRsp: giving up! portId=0x101e8, wwpn=0x21000020378707e4, loginRetryCo
unt=0x5, lldStatus=0x6, plc=0xca57f78
Jan 31 04:18:38: %FC-fci1-7-QPPLRPF: primaryPortLoginResp: PLOGI/PRLI failed status=0x6, loopId=0x81, portId=0x1
01e8, plcPtr=0xca57f78
*[cisco5428]# sh debug scsirouter all scsitrace
top 0x22130f8, bottom 0x221dfc0, current 0x22130f8, count 0x320
710: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
711: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
712: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
713: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
714: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
715: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
716: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
717: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
718: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
719: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
720: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
721: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
722: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
723: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
724: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
725: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
726: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
727: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
728: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
729: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
730: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
731: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
732: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
733: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
734: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
735: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
736: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
737: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
738: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
739: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
740: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
741: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
742: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
743: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
744: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
745: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
746: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
747: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
748: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
749: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
750: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
751: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
752: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
753: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
754: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
755: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
756: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
757: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
758: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
759: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
760: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
761: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
762: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
763: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
764: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
765: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
766: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
767: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
768: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
769: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
770: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
771: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
772: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
773: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
774: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
775: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
776: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
777: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
778: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
779: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
780: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
781: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
782: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
783: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
784: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
785: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
786: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
787: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
788: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
789: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
790: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
791: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
792: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
793: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
794: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
795: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
796: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
797: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
798: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
799: InttrID 0, TgtID 0, IF 0 VP 0, LUN 0, TmStmp 0x00000000
*[cisco5428]#
OK, I'll need to go over the complete That you will need to email.
