startup config missing in MDS9020 switch
srshet
I get failure message when copying running config to startup config.
In bootflash://
I see only running-config and startup-config is missing. is it possible to create startup-config? how do I fix this issue?
tblancha
Can you post your telnet session when you copy running-config startup-config and the subsequent error message?
# copy running-config startup-config
copy: Destination drive full -- write failed
It looks like a software defect which is CSCei15196. Please put in a call to your OSM or Cisco TAC.
