storage directly connected nexus 5672UP
packetpusher
greetings!!
We have had to amend our storage network due to a failed brocade.
Previously, we had 2 x Nexus 5672UP (with NPV enabled) 2 x fcports connecting to the brocades in NP mode.
The plan was/is to attach unity storage direct to our Nexus 5672UP 16G-FC eliminating the brocades totally.
I have amended the fc2/x ports to be switchport mode F and all the required ports (VFC interface bind to eth for servers) are in the correct VSAN, however I am getting a “npmExtLinkDown” from the show interface brief
fc2/11     2001   F      off     npmExtLinkDown             swl
fc2/12     2001   F      off     npmExtLinkDown             swl
There is no zoning in place and is not available on our nexus switch? Which is another issue…
Any help from the storage guru’s on this?
Cheers
Tommo
balaji.bandi
i believe it required a simple ISL Link to work, post the configuration
BB
Thanks for the response Balaji,
I should have mentioned that due to the failed brocade and it being a production environment we are in a non-resilient state with one of the NX switches still connected to the Brocade and then to the storage (live)
The plan is to remove the brocades if we can get the storage directly attached to the nexus…
Whilst researching this issue on another post it was suggested that the nexus’s need to have the feature “NPV” removed, config wrote, and then a reload,
As requested here is the config that I think you are after
feature fcoe
fabric-mode 40G
interface vfc1
  bind interface Ethernet1/1
  no shutdown
interface vfc2
  bind interface Ethernet1/2
  no shutdown
interface vfc3
  bind interface Ethernet1/3
  no shutdown
interface vfc4
  bind interface Ethernet1/4
  no shutdown
interface vfc5
  bind interface Ethernet1/5
  no shutdown
interface vfc6
  bind interface Ethernet1/6
  no shutdown
interface vfc7
  bind interface Ethernet1/7
  no shutdown
interface vfc8
  bind interface Ethernet1/8
  no shutdown
interface vfc9
  bind interface Ethernet1/9
  no shutdown
interface vfc10
  bind interface Ethernet1/10
  no shutdown
interface vfc11
  bind interface Ethernet1/11
  no shutdown
interface vfc12
  bind interface Ethernet1/12
  no shutdown
interface vfc13
  bind interface Ethernet1/13
  no shutdown
interface vfc14
  bind interface Ethernet1/14
  no shutdown
interface vfc15
  bind interface Ethernet1/15
  no shutdown
interface vfc16
  bind interface Ethernet1/16
  no shutdown
interface vfc17
  bind interface Ethernet1/17
  no shutdown
interface vfc18
  bind interface Ethernet1/18
  no shutdown
interface vfc19
  bind interface Ethernet1/19
  no shutdown
interface vfc20
  bind interface Ethernet1/20
  no shutdown
interface vfc21
  bind interface Ethernet1/21
  no shutdown
interface vfc22
  bind interface Ethernet1/22
  no shutdown
interface vfc23
  bind interface Ethernet1/23
  no shutdown
interface vfc24
  bind interface Ethernet1/24
  no shutdown
interface vfc341
  bind interface Ethernet3/4/1
  no shutdown
interface vfc342
  bind interface Ethernet3/4/2
  no shutdown
interface vfc343
  bind interface Ethernet3/4/3
  no shutdown
interface vfc344
  bind interface Ethernet3/4/4
  no shutdown
vsan database
  vsan 2001 interface vfc1
  vsan 2001 interface vfc2
  vsan 2001 interface vfc3
  vsan 2001 interface vfc4
  vsan 2001 interface vfc5
  vsan 2001 interface vfc6
  vsan 2001 interface vfc7
  vsan 2001 interface vfc8
  vsan 2001 interface vfc9
  vsan 2001 interface vfc10
  vsan 2001 interface vfc11
  vsan 2001 interface vfc12
  vsan 2001 interface vfc13
  vsan 2001 interface vfc14
  vsan 2001 interface vfc15
  vsan 2001 interface vfc16
  vsan 2001 interface vfc17
  vsan 2001 interface vfc18
  vsan 2001 interface vfc19
  vsan 2001 interface vfc20
  vsan 2001 interface vfc21
  vsan 2001 interface vfc22
  vsan 2001 interface vfc23
  vsan 2001 interface vfc24
  vsan 2001 interface vfc341
  vsan 2001 interface vfc342
  vsan 2001 interface vfc343
  vsan 2001 interface vfc344
  vsan 2001 interface fc2/11
  vsan 2001 interface fc2/12
  vsan 2001 interface fc2/13
  vsan 2001 interface fc2/14
  vsan 2001 interface fc2/15
  vsan 2001 interface fc2/16
  vsan 2001 interface fc2/17
  vsan 2001 interface fc2/18
  vsan 2001 interface fc2/19
  vsan 2001 interface fc2/20
  vsan 2001 interface fc2/21
  vsan 2001 interface fc2/22
  vsan 2001 interface fc2/23
  vsan 2001 interface fc2/24
feature npv
feature npiv
fcoe vsan 2001
interface fc2/11
  switchport speed 4000
  switchport mode F
  switchport description UnityA-0
interface fc2/12
  switchport mode F
  switchport description UnityA-1
sh license usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
FCOE_NPV_PKG                  No    -   Unused             -
FM_SERVER_PKG                 No    -   Unused             -
ENTERPRISE_PKG                Yes   -   Unused never       -
FC_FEATURES_PKG               Yes   -   In use never       -
VMFEX_FEATURE_PKG             No    -   Unused             -
ENHANCED_LAYER2_PKG           No    -   Unused             -
NETWORK_SERVICES_PKG          No    -   Unused             -
LAN_BASE_SERVICES_PKG         Yes   -   In use never       -
LAN_ENTERPRISE_SERVICES_PKG   No    -   Unused             -
sh run | in feature
feature fcoe
no feature telnet
feature interface-vlan
feature hsrp
feature lacp
feature dhcp
feature lldp
feature npv
feature npiv
