TACACS+
user_4444
We have two MDS 9509's and we want to move to TACACS access. The switches are running 3.0.1. Questions
1. Do both switches in the same fabric need to be upgraded to TACACS at the same time?
2. I have the cookbook for version 2, is the process any different from that?
3. Is there any nasties in doing this?
umedryk
Level 5
Level 5
When you set TACACS password protection at the privileged EXEC level, the EXEC enable command will ask for both a new username and a password. This information is then passed to the TACACS server for authentication. If you are using the extended TACACS, it also passes any existing UNIX user identification code to the server
