Timeout for Switch on Fabric Manager
thomaspaget
Community Member
I am getting timeouts for switch connectivity on Fabric Manager. The error in the log is below. Would this be a firewall issue?
An authentication problem? Or a configuration problem?
%SNMPD-3-ERROR: SNMP log error : usm_process_in_msg : SNMP UDP authentication failed for 172.x.x.x
Within Fabric Manager under Status the message shows timeout(Server)
blueyonderguy
Level 2
Level 2
is there a firewall in between?
which ports have you opened?
I am trying to gather ports needed for firewall but documentation has not been helpful. but make sure that udp port 2162 is opened from switch to FM server and same port has been manually specified on switch snmp config
Thanks, I was able to move the Fabric Manager server to the same subnet to bypass the firewall issues, so I never found out all the ports that are needed to be accessible.
