Troubleshoot connectivity with Cisco MDS 9124
Lotfi BOUCHERIT
I recentrly discovered that it's become impossible to connect to a CISCO MDS 9124, neither with SSH nor with Serial connection.
What should i do please to resolve that issue please?
Regards!
dakester
Are you able to access the 9124 by Device Manager, web browser, telnet, or ssh when your laptop is directly connected to the mgmt0 interface and your laptop configured on the same subnet as the mgmt0 interface?
What console settings, console cable, terminal emulator application are you using and does it work with another MDS9000?
David
6 Replies 6
dynamoxxx
Level 5
Level 5
what happens when you connect to the console ?
@dynamoxxx
@dynamoxxx
when i connect to the console, nothing happens
when i try ssh, it says, disconnected
i should mention too, that pinging that fc switch is successful
thanks for your reply, and looking forward for your help
regards
Do you know what version of code is the MDS 9124 running?
hello,
i think that it's the default version, (3.1 ?)
i don't think that the previous administrator might upgrade or change it..
thanks in advance
dakester
David
hello,
actually we just have one fc switch
for the information used to connect to the console:
>terminal : putty
>baud rate : 9600
>parity :  none
>stopbits : 1 bit
i mean the defaults, even the ssh, it does not give at least that warning about security certificate
regards
