UCS C200 M2 with raid 5
MRPFNZCCO
I'm trying to figure out if I can run raid 5 with four new ssd drives I have connected.  The LSI Raid utility only shows raid 0,1 and 10 but raid 5 is greyed out.  How do I get raid 5 option available. If raid 10 is supported why wouldn't raid 5 be?
Walter Dey
see eg.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/raid/configuration/guide/RAID_GUIDE.pdf
Which Raid-Controller do you have
Table C-1 Cisco UCS C200 LFF RAID Options (Up to Four 3.5-Inch Internal Drives)
Controller
Style
Max. Internal Drives
SAS
SATA
Opt. BBU
RAID Levels
Required Cables
Intel ICH10R 1
Integrated
No
Yes
No
0, 1
1 SATA
R200-SATACBL
LSI 1064E
Mezzanine
Yes2
Yes
No
0, 1, 1E
1 SAS
R200-SASCBL
LSI MegaRAID 9260-4i
PCIe
Yes3
Yes
Yes
0, 1, 5, 6, 10, 50, 60
1 SAS
R200-SASCBL
LSI MegaRAID 9280-4i4e
PCIe
Yes
Yes
Yes
1 SAS
R200-SASCBL
It's using the LSI controller but I'm trying to figure out if it's using the Mezzanine controller or the PCIe.  On boot up it's showing (see attachment)
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C200M1/install/c200M1/RAID.html#98288
How to Determine Which Controller Is in Your Server
If no models of card are displayed but there is a RAID configuration, your server is using the
onboard ICH10R controller. You are also prompted to press Ctrl-M to launch the configuration utilities for this controller.
According to this, you are using the integrated controller ! and this is the reason, that raid-5 is not supported !
That's what I was afraid of. Control M brings up the LSI utility which shows Raid 0, 1 and 10 options.
