Upgrade Question
pgirish_2000
Visitor
We are looking at upgrading our 9513s from v3.2.2c to 4.1.3a. The upgrade procedures in the docs look quite straightforward. Has anyone experienced any issues/glitches during the upgrade ?
Girish
Yes, I believe it is. The way i approached it was:
1.Did the 3.3x upgrade
2.did the 4.1x upgrade
3.powered off the switch and added the new fabric-2 modules, and any 8gb modules (this can be skipped if you are not needing 8gb module support)
4.powered on the switch (this can be skipped if you are not needing 8gb module support)
5.upgraded fabric manager to 3.3x, never launched it.
6.upgraded fabric manager to 4.1x, logged in to verify everything worked.
this worked flawlessly for each 9513 i upgraded.
Nikhil Sharma
Girish,
If you are looking for a non-disruptive upgrade path, I would suggest you upgrade to 3.3.x first. This is also discussed in the release notes which can be found here: http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/4_1/release/notes/17675_05.html
Also it depends on what features you are using on the MDS. The release notes discuss all of these scenarios.
- Nikhil
Girish,
Nikhil is correct. you need to do a 2 step upgrade. first to 3.3(x) and then to 4.1(x). Also if this is take advantage of 8gb modules then you will need to make sure you have upgraded your fabric modules to fabric-2 modules (x-bars. the final step to take advantage of the 8gb modules is to do a reload (bounce) the switch after the 4.1(x) upgrade (which is disruptive).
Thanks Nikhil and Suntzzu. Is the two-step process also true for the fabric manager upgrade from 3.2.2c to 4.1.3a?
Girish
