08-08-2007 07:38 AM
I was able to rename a vsan via cli. I could not figure out a way to do this from FM 3.1(2). Did I miss it?
08-14-2007 06:58 AM
You can rename IVR zones and IVR zone sets.
To rename an IVR zone or IVR zone set, using Fabric Manager, follow the steps in
08-15-2007 09:26 AM
You can rename VSANs from FM. Just click on the "All VSANs" under the appropriate fabric in the upper left (logical domains pane). This brings up the table of all the VSANs in the upper right pane, where you can change the name (but not the VSAN number) and then click 'apply'.
