WAFS + Shares
casablancag
i'm tring to implement 2 WAFS engine 3.01. I configured both Engines and i could enable Print Services but if I try to connect e.g \\wcwe001t (Edge) I see only the Printer and not the Shares. In the samba error.log I got following entry:
[2005/11/23 10:11:49, 0] smbd/service.c:make_connection(793)
wcwe008z (10.226.0.105) couldn't find service ::{2227a280-3aea-1069-a2de-08002b30309d}
Any suggestion ??
a-vazquez
Level 6
Level 6
I think what you are seeing is the expected behaviour. With WAFS you will not be able to see the shares.
wei.haihong
Did you configure the File Servers in your WAFS enviorment?
I think you can't see the shares if there is no servers configured.
If you configured the Print Services, it is an exact
behavior that you can see the Printers.
2)
Remember the File Server user which you configured
in the Core Engine must be assigned with the content
list right.
