Remote SAN
umar-rana
Community Member
We have one site configured for services. All the servers are using SAN for storage. We need create a backup site with same hardware 30kms far. The SAN hardware at both locations needs to communicate. We are using Cisco SAN switches. Both locations can only be connected via E1 links.
How two SANs would be connected? We cannot have direct fibre link between SAN switches.
oerkan
Level 2
Level 2
Hi Umar-Rana,
You may consider FCIP(Fibre Channel over IP Protocol). It is a tunneling protocol that connects geographically distributed Fibre ChannelSAN islands transparently over IP LANs, metropolitan area networks (MANs), and WANs.
You can find the further details on the following URL :
http://www.cisco.com/univercd/cc/td/doc/product/sn5000/mds9000/2_0/cliguide/part6/cfcip.htm
For the FCIP, you will need IPS module on the switches.
Hakan.
ozkarakok
Community Member
Hi Umar,
I suppose before you order your Cisco MDS switches you have contacted with local Cisco engineers.Depending on the modules that you have ordered , you can use your existing IP network to carry your FC traffic via using FCIP.
Here is an example of basic FCIP config:
http://www.cisco.com/en/US/partner/tech/tk1048/technologies_configuration_example09186a00801e6f03.shtml
Fibre Channel over IP Design Using the Cisco MDS 9000
http://www.cisco.com/en/US/partner/products/hw/ps4159/ps4358/products_white_paper09186a0080177bd4.shtml
Understanding Alternatives for Extending Storage Networks
http://www.cisco.com/en/US/partner/products/hw/ps4159/ps4358/products_white_paper09186a008020805e.shtml
I hope this answers your question.
Kind regards,
Ozden Karakok
The_guroo_2
Level 7
Level 7
well buy a fiber termination CPE connect it with router?? i guess this will help
