Waiting for flogi
jfcai2004
I have one C220 connects to Nexus 5548UP via FCoE, but the vfc is in trunking, and the vsan is waiting for flogi.
Below is the conf,
vlan 1000
  fcoe vsan 1000
vsan database
  vsan 1000
interface vfc1
  bind interface Ethernet1/1
  switchport trunk allowed vsan 1000
  no shutdown
vsan database
  vsan 1000 interface vfc1
  switchport mode trunk
  switchport trunk allowed vlan 1,1000
  spanning-tree port type edge trunk
N5548# show int vfc 1 trunk vsan
vfc1 is trunking
    Vsan 1000 is down (waiting for flogi)
Any reason?
Jeff
13 Replies 13
Marcel Zehnder
Hi Jeff
Looks to me like an issue on the C220 - Could you please post some screenshots from the interface/vHBA-Config on your C220?
Marcel
Thanks, Marcel.
ucs-c220-m3 /chassis/adapter/host-fc-if # show detail
Name fc0:
    World Wide Node Name: 10:00:54:78:1A:87:35:2C
    World Wide Port Name: 20:00:54:78:1A:87:35:2C
    FC SAN Boot: disabled
    Persistent LUN Binding: disabled
    Uplink Port: 0
    MAC Address: 54:78:1A:87:35:2C
    CoS: 3
    VLAN: 1000
    Rate Limiting: OFF
    PCIe Device Order: ANY
    EDTOV: 2000
    RATOV: 10000
    Maximum Data Field Size: 2112
    Channel Number: N/A
    Port Profile: N/A
Is this enough?
Okay, looks good - I know about an similar issue if you don't configure the FCoE-awere QoS policy-maps on your N5k.
What is the output if you do a  "sh run ipqos all" on your N5K?
# sh run ipqos all
!Command: show running-config ipqos all
!Time: Wed Mar 13 16:05:36 2013
version 5.1(3)N2(1c)
class-map type qos class-fcoe
class-map type qos match-any class-default
class-map type qos match-any class-all-flood
class-map type qos match-any class-ip-multicast
class-map type queuing class-fcoe
  match qos-group 1
class-map type queuing class-default
  match qos-group 0
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing class-ip-multicast
  match qos-group 2
policy-map type qos default-in-policy
  class class-default
policy-map type qos fcoe-default-in-policy
  class class-fcoe
    set qos-group 1
  class class-default
policy-map type queuing default-in-policy
  class type queuing class-default
    bandwidth percent 100
policy-map type queuing default-out-policy
policy-map type queuing fcoe-default-in-policy
  class type queuing class-fcoe
    bandwidth percent 50
policy-map type queuing fcoe-default-out-policy
class-map type network-qos class-fcoe
  match qos-group 1
class-map type network-qos class-default
  match qos-group 0
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
policy-map type network-qos default-nq-policy
  class type network-qos class-default
    multicast-optimize
policy-map type network-qos fcoe-default-nq-policy
  class type network-qos class-fcoe
    pause no-drop
    mtu 2158
    multicast-optimize
system qos
  service-policy type qos input fcoe-default-in-policy
  service-policy type queuing input fcoe-default-in-policy
  service-policy type queuing output fcoe-default-out-policy
  service-policy type network-qos fcoe-default-nq-policy
  fex queue-limit
  priority-flow-control mode auto
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet1/4
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
Looks good as well...I'm out of ideas - sorry.
One last shot:
Try:
int vfc1
shut
switchport mode f
no shut
BTW, can I connect C220 direct to 5548?
same.
show int vfc 1
vfc1 is trunking
    Bound interface is Ethernet1/1
    Hardware is Ethernet
    Port WWN is 20:00:00:2a:6a:0a:66:ff
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
    Port mode is TF
    Port vsan is 1000
    Trunk vsans (admin allowed and active) (1000)
    Trunk vsans (up)                       ()
    Trunk vsans (isolated)                 ()
    Trunk vsans (initializing)             (1000)
we do not install OS yet, and want to use SAN boot.
If you have local HDD, just give a try with installing a simple o/s lke ESXi & then check flogi.
This eliminates lots of unnecessary troubleshooting & narrow down the issue whether it is SAN boot issue or HBA issue.
We have done SAN boot with UCS blades with boot policy set to SAN specifying the pwwn of the storage port & respective LUN ID as target.
Hello Jeff,
I had the same problem with the same configuration as yours.
First of all we ugraded the version of our Nexus from 5.1(3) to 5.2(1) N1 (3)
The problem is that the CIMC didn't sync the BIOS with the boot from SAN flag.
I just reboot the server with the kvm chose F2 to enter the bios settings then F9 to reset the default parameters and reboot...
And that doesn't reset the BIOS, that update it ! The server boot from SAN and i could install VMware on the lun.
Hello Herve,
We found the RAID controller is failed. When we pressed  F2 or F6, it just displayed Entering setup or Entering boot menu...,  until we removed RAID controller.
Then we update the firmwares on C220, we can configure LUN and we can install the ESXi on the LUN.
But when reboot, we could not find the LUN for boot in the boot menu. Any suggestion?
Jeff
Hello
You should verify that the HBA has initialized. I have experienced this similar issue with Qlogic cards, basically right out of the box you have to enter into the card during boot and actually turn on FCoE. The Qlogic gives the ability to connect and test the SAN connection over FC in its BIOS. Please note that sometimes a cold reboot of the server is needed before flogi appears. You can issue the sho int vfc , also show flogi data. You will hopefully see the cards PWWN and the vfc interface number.
This is based on my experience with dell and hp using Qlogic CNAs.
We find the issue is the battery of the RAID controller.
Sometime we will get following messages on screen:
USB cache device is not responding.
From the link
http://www.cisco.com/en/US/docs/unified_computing/ucs/release/notes/OL-28995-01.html
We find following solution:
Workaround
Power  down the system for 2 minutes to attempt recovery and avoid cache data  loss, and then power-on. If it fails, replace SuperCap with newer Rev-K  SuperCap (49571-03). (CSCud38069)
After replace the SuperCap, the issue solved. Now we can use the SAN boot.
Really bad experience.
