What is upstream swith and downstream switch
ciscomagic1
Please give me some lecture on this question, it'd be great if you have some diagrams.
Thanks for your time in advance.
Yes, they need to be in the same VSAN for them to login to Fabric and see each other.You also need to configure Zone and activate the zone-set for the storage and server to talk to each other. If they are in different VSAN's, you have to use IVR and IVR zones for them to see each other.
Thanks for the link.
I guess, I need to ask more particular questions. The following is what I excerpted from page 5-3 on this document: http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/troubleshooting/guide/n5K_ts_sans.pdf
"A server port connected to the NPV edge switch does not come online, and the show interface command
indicates a status of NPV upstream port not available.
Possible Cause:
The upstream NP_Port(s) and the downstream server F_Port(s) on the NPV edge switch may not be in
the same VSAN. "
Just wanted to confirm with understand the issue. To resolve the problem, in the case as following, fc2/2 on the upstream switch should be in the same VSAN as the port fc1/5 on the downstream switch? Am I understanding it right?
fc2/2, NP_Port, To a storage
|         |     <-------upsream switch
|        |      <-----downstream edge
  fc/1/5, F_Port, To a server
