while configuring speed 1000 i am getting error as sw2-storage-vdc(config-if)# speed 1000 ERROR: Ethernet2/6: Configuration does not match the port capability.
ankjain3
storage-vdc(config-if)# show module
Mod  Ports  Module-Type                         Model              Status
2    32     1/10 Gbps Ethernet Module           N7K-F132XP-15      ok
sw1-gd78(config-if)# sh module
2    48     1/2/4/8 Gbps FC Module              DS-X9248-96K9      ok
4    8      10 Gbps FCoE Module                 DS-X9708-K9        ok
7    0      Supervisor/Fabric-2a                DS-X9530-SF2AK9    active *
8    0      Supervisor/Fabric-2a                DS-X9530-SF2AK9    ha-standby
10   22     4x1GE IPS, 18x1/2/4Gbps FC Module   DS-X9304-18K9      ok
Mod  Sw              Hw      World-Wide-Name(s) (WWN)
2    5.2(2)          1.1     20:41:00:0d:ec:fb:8a:00 to 20:70:00:0d:ec:fb:8a:00
4    5.2(2)          0.107   --
7    5.2(2)          1.8     --
8    5.2(2)          1.8     --
10   5.2(2)          1.3     22:41:00:0d:ec:fb:8a:00 to 22:52:00:0d:ec:fb:8a:00
sw1-gd78(config-if)# sh run int ethernet4/6
!Command: show running-config interface Ethernet4/6
!Time: Mon Feb 20 22:56:12 2012
version 5.2(2)
  no shutdown
sw1-gd78(config-if)# no shut
sw1-gd78(config-if)# speed 1000
ERROR: Ethernet4/6: Configuration does not match the port capability.
sw1-gd72# sh int ethernet4/6 capabilities
Ethernet4/6
  Model:                 DS-X9708-K9
  Type (SFP capable):    10Gbase-SR
  Speed:                 1000,10000
  Duplex:                full
  Trunk encap. type:     802.1Q
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off/on/desired),tx-(off/on/desired)
  Rate mode:             dedicated
  QOS scheduling:        rx-(2q4t),tx-(1p3q4t)
  CoS rewrite:           yes
  ToS rewrite:           yes
  SPAN:                  yes
  UDLD:                  yes
  Link Debounce:         yes
  Link Debounce Time:    yes
  MDIX:                  no
  Port Group Members:    none
  TDR capable:           no
  FabricPath capable:    yes
  Port mode:             Switched
sw1-gd72# sh int ethernet4/6 transceiver details
Ethernet4/6
    transceiver is present
    type is 10Gbase-SR
    name is CISCO-FINISAR
    part number is FTLX8571D3BCL-CS
    revision is C
    serial number is FNS12090EMJ
    nominal bitrate is 10300 MBit/sec
    Link length supported for 50/125um OM2 fiber is 82 m
    Link length supported for 50/125um OM3 fiber is 300 m
    Link length supported for 62.5/125um fiber is 26 m
    cisco id is --
    cisco extended id number is 4
           SFP Detail Diagnostics Information (internal calibration)
                                     Alarms                  Warnings
                                High        Low         High          Low
  Temperature   36.21 C        75.00 C     -5.00 C     70.00 C        0.00 C
  Voltage        3.29 V         3.63 V      2.97 V      3.46 V        3.13 V
  Current        8.11 mA       11.80 mA     4.00 mA    10.80 mA       5.00 mA
  Tx Power       -2.65 dBm       1.49 dBm  -11.30 dBm   -1.50 dBm     -7.30 dBm
  Rx Power       -2.21 dBm       1.99 dBm  -13.97 dBm   -1.00 dBm     -9.91 dBm
  Transmit Fault Count = 0
  Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning
Ankit,
You are trying to set speed 1000 on a 10g sfp.
type is 10Gbase-SR
You will need to insert a 1gig sfp and then you will be able to set the speed.
Also, I noticed that you posted first with interface 2/6 and the output you gave me was for 4/6. Are you sure you're in the right interface?
Amanda Hunt
Can you post a "show mod" and "show int eth 2/6 capa" output? Some of the modules don't support 1gig functionality so your speed 1000 command will fail.
Hi Amanda
I have added.
Ankit,
type is 10Gbase-SR
Thanks Amanda....The point You made we have also noticed (type is 10Gbase-SR)...one more question is we cannot configure lesser speed (1G)in our case?
as you talked about interface so these two interface was ISL in my case having same configs.
