03-18-2025 04:36 AM
We met a strange on my mds cisco switch . After make connect to interface from my device according to follow pic it is showing twice for fc1/23 . Why happened this issue ?
03-18-2025 04:40 AM
they are 2 different MAC address - what is that connected to ?
03-18-2025 01:10 PM
As you can see there are difference wwpn and I just make one connection from a device to interface fc1/23 on MDS but why is showing twice interface name fc1/23 ?
06-01-2025 05:49 PM
Hello @BabSimon,
It seems like you posted this a while ago, but I wanted to take a moment to provide a response in case others have a similar question.
The output you shared appears to be from the show flogi database detail command, where two PWWNs are logged into the same interface.
When this occurs, and the interface is connected to either an initiator (host) or a target (storage array), it typically indicates that the device is using N-Port ID Virtualization (NPIV). NPIV is a Fibre Channel standard that allows a single physical Fibre Channel port (N-Port) to register multiple World Wide Names (WWNs) with the fabric. This enables multiple virtual or logical devices to share the same physical port.
I hope this explanation helps!
